Cubase Bank Change Blues
Page 1 of 1 [10 Posts]
BobTheDog
PostPosted: Sun Sep 11, 2005 9:21 am    Post subject: Cubase Bank Change Blues Reply with quote  Mark this post and the followings unread
Hi Everyone,
I am pulling my hair out here and maybe someone that uses cubase can stop me going totally bald.
When cubase sends bank change messages to my G2 it totally ignores them and always uses bank 1.
Can anyone help me to get the thing to understand it has more than 1 bank.
Any help would be really really aprecieted.
Andy
Leo G2
PostPosted: Sun Sep 11, 2005 11:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
i dont know the G2 very well yet, but have you tried the other way round? change banks from within the G2 and record it in Cubase. then see what Cubase has recorded and use that to change banks in the G2.
i hope it works. still, i don't think changing banks or programs within a song has had a lot of priority when Clavia designed their synths.
and really, most sounds are nice enough to at least last a song!
sinswolf
PostPosted: Mon Sep 12, 2005 11:08 pm    Post subject: G2 and Cubase Reply with quote  Mark this post and the followings unread
Hi BobTheDog,
I use Cubase SX 3.0 with the G2 and it works fine (with the exeption that in some circumstance ma G2 freeze), I've loaded the Nordmodular Patchname script in Cubase. Cause its an older version and due the flexibel structure of the G2 the patchnames are not matching, but you can edit them. If you like, I can send you the script, but you can find it also on one of the older SX CDs.
BobTheDog
PostPosted: Tue Sep 13, 2005 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info.
Have you upgraded to 3.1? I'm beginning to wonder if it is a 3.1 problem.
I'll have a look on the Cd's for the file.
Andy
BobTheDog
PostPosted: Tue Sep 13, 2005 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sinswolf,
The only scripts I can find are for the old nord modular (versions 2.0 and 3.0) and the nord lead!
Are you useing one of these?
Andy
sinswolf
PostPosted: Tue Sep 13, 2005 2:13 am    Post subject: Cubase and G2 Reply with quote  Mark this post and the followings unread
Hi Bob,
I think I use the old Modular Patchnamescript
Try it and let me know if it works.
sinswolf
PostPosted: Tue Sep 13, 2005 11:56 am    Post subject: G2 and Cubase SX3 Reply with quote  Mark this post and the followings unread
Hi Bob,
I've updated my Cubase SX 3 to 3.1 and everything works well.
I use a Script Nord Modular 2.0. the Script is in the attchment
NMG2.zip
Nord Modular Script
 Filename:  NMG2.zip
 Filesize:  132.86 KB
 Downloaded:  258 Time(s)
NMG2.zip
 Filename:  NMG2.zip
 Filesize:  132.86 KB
 Downloaded:  259 Time(s)
BobTheDog
PostPosted: Thu Sep 15, 2005 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats very kind of you.
I have been struggling trying to load in a .txt script file for the pathnames.
How did you generate the xml file?
Andy
BobTheDog
PostPosted: Fri Sep 16, 2005 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again,
Still didn't have much luck with your script changeing banks properly!
I have written a program that creates a patch script for cubase that works will all banks and patches.
At the moment it just displays patch names as 1-1 for bank 1 patch 1, 2-23 for bank 2 patch 23 etc.
I am going to modify this program to also read .pchList files that have been uploaded from the G2 to put the correct patchnames in. Then I am going to try modify it to allow variation selection as well, but I dont know if cubase scripts allow this. The new XML device format does but I do not understand how to create this!
When I have finished this program I will upload it here, It will be for pc's not for macs. I could include the source code as well for someone to port to a mac.
I have included a zip file with the patch script in. Unzip the .txt file into:
C:\Documents and Settings\USERNAME\Application Data\Steinberg\Cubase SX 3\Scripts\Patchnames\inactive
Replace USERNAME with your username, you may need to create this directory.
Now you should be able to install the device in the cubase MIDI device manager.
Andy
Clavia Nord Modular G2.zip
 Filename:  Clavia Nord Modular G2.zip
 Filesize:  12.64 KB
 Downloaded:  266 Time(s)
BobTheDog
PostPosted: Sat Sep 17, 2005 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
please see http://www.electro-music.com/forum/post-51973.html#51973
