 Forum index » Clavia Nord Modular » G2 Patches - Completed » Pad
Quadrat
Page 1 of 1 [4 Posts]
G2 patch files: 626
PostPosted: Fri Oct 07, 2005 5:16 pm    Post subject: Quadrat Reply with quote  Mark this post and the followings unread
The PWM option on shape Oscillator B is a nice low dsp option. This patch uses a 90deg phase shifter, two saw to triangle converters and a couple of inverters to get 4 phase shifted triangle modulators for each pulse width.
The saw to triangle converters (yellow) should in theory have a level converter on them to create a bipolar wave, but because the shape mod has both a level and offset, I could drop it to get 1 more voice.
4 variations.
quadrat1.pch2
quad pwm pad
 Filename:  quadrat1.pch2
 Filesize:  2.48 KB
 Downloaded:  2308 Time(s)
Audio files: 228
PostPosted: Sat Oct 08, 2005 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice, Ian. Beautiful sounds. Do you use an engine? There are no know assignments.
G2 patch files: 626
PostPosted: Sat Oct 08, 2005 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm just lazy Embarassed .
I've reposted with some basic assignments. Maybe Clavia could do a one click assign so that all the oscillators go to A, filters go to D etc. Or have it as an alternate "Patch" mode, which would be more intuitive than using the Navigator buttons.
dxmat
G2 patch files: 8
PostPosted: Sun Oct 09, 2005 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent sound. Very deep pad.
DXmat
