Volume drop between variations
Page 1 of 1 [5 Posts]
AngusHastie
PostPosted: Wed Dec 07, 2005 7:29 am    Post subject: Volume drop between variations Reply with quote  Mark this post and the followings unread
Hi all,
Can anyone shed any light on why, in the attached patch, if I change from variation 2 to var. 1, the volume in var. 1 is really low. But if I change to var. 3 and then to var. 1, the volume is as it should be...?? Confused
Angus
variation volume glitch.pch2
 Filename:  variation volume glitch.pch2
 Filesize:  3.22 KB
 Downloaded:  1251 Time(s)
Audio files: 228
PostPosted: Wed Dec 07, 2005 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow. I can reproduce this on my G2X, so you're not hallucinating, at least about his patch. Laughing
This is a stumper. I think the problem is in the yellow Filter Static module on the far right of the poly area because if you switch on the bypass button, the volume change going from var 2 to 1 goes away.
Explaining it is another thing. Maybe some guru can enlighten us. That's as far as I can get.
AngusHastie
PostPosted: Wed Dec 07, 2005 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I get that too. And if you just tweak one of the filter knobs a tiny bit, the volume jumps up again. Very bizarre. Would appear to be a bug in that module. The other wierd thing is that it only happens when switching from v2 to v1, none of the other variations. And I don't have anything assigned to morph groups.
One thing I have notiiced is that it happens when the filter is set to hi-pass in the previous variation...
PostPosted: Wed Dec 07, 2005 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I strip down the patch to one osc (doesn't matter what type), the filter and an output module the problem is still there. It's as if on variation change some parameters of the filter are not updated. Seems definitely a bug to me, can't think of anything else (I removed all morphs and all front panel knobs as well, just to be sure).
I'd report it it to Clavia, as otherwise the 1.4 software will certainly still have this.
simplest form of the G2 static filter bug
 Filesize:  51.88 KB
 Viewed:  4366 Time(s)
AngusHastie
PostPosted: Wed Dec 07, 2005 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Reported it to Clavia...
