The power to do my thang!- Introducing Mr Scott Stites :D
Page 2 of 2 [49 Posts]
Goto page: Previous 1, 2
PostPosted: Sat Jan 07, 2006 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Copenhagen lysergics still rocks. Dunno.. Perhaps this is a EU thingie.
Flickr
PostPosted: Sat Jan 07, 2006 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
g2ian wrote:
surely it would be better to just duplicate its meager functions using readily available CMOS?
Or a processor, or a couple of processors, with voltage controlled clocks. I'm sure some PIC10 or 12 devices (costing about a dollar) could do miracles when properly programmed :-)
Scott Stites
Audio files: 96
PostPosted: Sat Jan 07, 2006 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not drawn to any cutlish or mojo-like aura of the SN76477 (though I am fond of the timbre of the PWM it produces). By the same token, in terms of scale, I would not list its assets as terribly meager.
Consider in one LSI you have an LFO, a linear VCO, a pre-randomized shift register with a controllable filter on the output, an envelope generator and a built in addressable mixer.
The noise generator pseudo-random length is adequate enough to have a fairly long cycle without repeating, which would take perhaps a couple of 4015's and EXOR's to randomize it. You'd have to rig a VCO and an LFO (triangle, mind you), a means to modulate one with the other, a mixer, and a at least one multiplexer. To control the level of the shift register out, you're going to need something on the order of a controllable amplifer or filter. For the output of the thing, a VCA would have to be rigged. Then of course, you would need rig a fairly simple EG.
None of that is rocket science. The point is, for a nice little accessory to the Sound Lab or something along those lines, this would be a means of producing some potentially interesting results with a minimum of circuitry. And, it would be a gas to do. Grab the SN76477, slap some extraneous circuitry to it, and go on your merry way. For me, that's the point of the idea.
A CMOS/Linear adaption (much more cirucitry) or a PIC or two (a little bit more circuitry and programming) would be preferable for numbers greater than a onesies/twosies. But, in that case, why emulate the SN76477?
Cheerio,
Scott
PostPosted: Sat Jan 07, 2006 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree Scott,
Sometimes we should play around with old technology simply because it's fun to play around with old technology. Cool
PostPosted: Sun Jan 08, 2006 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly- it's missing the point. And despite the PIC idea being a cheap chip to buy- a fair amount of time would have to be devoted to programming it. Why bother with all that hassle if the chip to do it, is already there?
btw, I can tell you don't have kids Jan!!! Laughing
ACHTUNG!
PostPosted: Sun Jan 08, 2006 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
True, why limit oneself Very Happy
PostPosted: Sun Jan 08, 2006 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
btw, I can tell you don't have kids Jan!!! :lol:
Hmm, but still have no time ...
Wild Zebra
PostPosted: Tue Jan 10, 2006 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Allright, with all that being said. Is this a go. Have we gained interest?
I'll the electronic geniuses get it started. Sounds like it could be real cool. I chip, lots a fun, space invaders, dang.
"your stripes are killer bro"
PostPosted: Tue Jan 10, 2006 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay- I've got to get these next couple of weeks out of the way (until the end of semester)- up to my teeth in assignments Sad
I'm well up for this (I may even treat myself to a PC (or get XP and run it under iEmulator)) so I can run schematic designer.
The actual circuit I reckon will be really easy. But I should add that there are different sized SN7's around. The one I sent you Zebra was the original sized one. Mine is much smaller (but not a surface mount type). It has an 'N' on the end I think.
ACHTUNG!
Wild Zebra
PostPosted: Tue Jan 10, 2006 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll treat myself to a couple of beers in your honor. As soon as I get out of this bloody job!!!!! Well keep me posted anything I can do in my limited knowledge to get this off the ground.
that suckers as big as a hissing cockroach
PostPosted: Tue Jan 10, 2006 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes Beer! We're gonna need a lot of that too!!! Smile Especially when you realise that Mosc (or was it Stein?) has duped me into this position of moderator- and reckons I'm some super-duper electronics techie (Mr Bicycle repairman? Very Happy ) when I too am more of a 'paint by numbers' sort of chap! LOL!
got some new super- psychedelic prog CD on the turntable right now. I'm diggin' it!
yes everything's groovy Smile
I don't know if you can get it in the States, but one of my favourite bottled English beers is Theakston 'Old Peculier' 5.6%vol. I recommend you sink some bottles Smile
for the web-minded;
http://www.theakstons.co.uk/
Wild Zebra
PostPosted: Wed Jan 11, 2006 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I can, I've had it in the past. I'll have to stop by the brew shop and pick a couple up. It's been awhile. Have to get reaqainted> We have a small place in the states called Rogue with some tasty heavy duty beers 1e. Dead Guy Ale, Arrogant Bastard, Double IPA, goog stuff.
dnny
PostPosted: Wed Jan 11, 2006 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
well im interested - and i have been lookin that datasheet now for a while. so soon i will have some idea what is this ancient chip we are dealing here.
Wild Zebra
PostPosted: Wed Jan 11, 2006 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link dnny. I hadn't seen that yet. Boy, that chip has alot going on. Let's exploit the heck out of it!!!
PostPosted: Wed Jan 11, 2006 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's litterally hundreds of different Ales in this country- but alas a lot of them are also dying out because of unscrupulous companies such as the US equivelent of Budweiser "Budweiser"- these piss artists make utterly shit beer, so when ever I can I go for The real Budweiser- brewed in the Czech Republic. Although I'm not really a lager fan- Budvar is nice on a really hot day Smile
Arrogant Bastard sounds good Smile 'Old Bill' used to be good to- and 'old bailey' too. Wells' Brewery's 'Banana Bread Beer' is a sure fired winner too in the bottled states- as is Bombardier.
getting thirsty now Very Happy
ACHTUNG!
Wild Zebra
PostPosted: Wed Jan 11, 2006 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
getting thirsty now
me too!!
Its not a promise, but maybe one of these days I'll send a sixer.
Is this a beer forum or an electronics forum?? Cool Laughing
PostPosted: Wed Jan 11, 2006 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I reckon so Smile
In the meantime, this was a site I bookmarked a while back. Most of its in German- but all the circuits are there. Check out the cute 'minisynth' SN7 unit. There was an identical circuit in ETI (Electronics Today International) in this country in the late 70's. I'd love to know what the stylophone unit sound like too Very Happy
That site:
http://home.pages.at/pullrich/m_music3.htm
Tom
ACHTUNG!
dnny
PostPosted: Sun Jan 22, 2006 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
have you seen this videoclip of SpaceSynth?
the SpaceSynths are made from the SN76477 (Space Invader) chips by Tony from ElectroKraft.
the video is great but the sounds don´t impress me - because whit one modded-WSG you could do almost the same and more.
so are there any samples where this chip is taken to it´s limits?
and if anyone knows where to get one of those SN7677 I'm interested -
so by experimenting i could learn more about this chip and finally fall in love whit it.
daniel
PostPosted: Sun Jan 22, 2006 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm- Blacet made a very similar device in the early 80's called the 'synbow'. But my idea was to use the SN7 as a modulation source, NOT a sound source. This way you can still use your favourite vintage sounding analogue monster instead of having to listen to just the SN7 sound source.
I'll have another look soon for the chip again (so you people can start experimenting!)
Tom
ACHTUNG!
toppobrillo
PostPosted: Thu Jan 26, 2006 10:19 pm    Post subject: sn76477n'n Reply with quote  Mark this post and the followings unread
hey-o
im a recent join of this electroforum thing.
i got one of those [complexsoundgenr8rs].. still in the package actually.
i haven't committed it to anything yet.
i have studied over every application for it i can find on the net.
which does not include schematics for the supercontroller, DSC or synbow,
unfortunately..
i would definitely like to see those too, so if any of you guys got'em and
wouldn't mind sharing a peek, lemme know. greatly appreciated and if i can be of any help to the cause i surely will.
byu the way, have youall seen the "arcade synth" PIC interface project for the 76477? i ran across it not too long ago.. checked it out?
joshr
PostPosted: Fri Jan 27, 2006 4:25 am    Post subject: Re: sn76477n'n Reply with quote  Mark this post and the followings unread
joshr
hello joshr welcome to electro-music.com Smile
How can we see this PIC interface thingie if you don't put a link to the site? Shocked Cool Very Happy
ACHTUNG!
toppobrillo
PostPosted: Fri Jan 27, 2006 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
first see this:
http://experimentalistsanonymous.com/board/topic-79-0-15.html
then download this:
http://experimentalistsanonymous.com/diy/Schematics/Full%20Synths%20and%20Drum%20Synths/Arcade%20Synthesizer.zip
i am going to put this on the "sn76477" forum entry
Audio files: 235
PostPosted: Fri Jan 27, 2006 5:13 pm    Post subject: Re: sn76477n'n Reply with quote  Mark this post and the followings unread
topp wrote:
hey-o
Yo! welcome
Great to have you here...
PostPosted: Fri Jan 27, 2006 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice one : that beatbox gif is similar to what Ive got in mind. But howabout we automate those pots too- using a simple step sequencer?
I'm looking along the idea of an analogue 'nanoloop' type affair- which can be interfaced to external v.c. gear etc Smile
This is a nice circuit and a good place to start Very Happy
cheers!
ACHTUNG!
