8 bits with a G2 , how to ?
Page 2 of 2 [26 Posts]
Goto page: Previous 1, 2
Kassen
PostPosted: Fri Jan 13, 2006 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
g2ian wrote:
here is a lo bit DIY A2D and D2A
The D2A is just a mixer, summing and scaling the 3 output bits, changing the mixer levels will introduce errors Rolling Eyes
The A2D uses compare level modules and the subtracting mixer, one pair for each bit. This example uses the spare mixer inputs to allow some bits to interfere with other sections. Just as an experiment, the LSB has a random trigger on it, probability modulated by the middle bit.
I'm just processing a pos only signal then converting to bipolar later.
Sounds more interesting on complex signals.
Yeah, that sounds exactly like what it should be (the Laptop isn't on right now). Using a mixer as a simple DAC isn't all that strange, realy. My CMOS book here sugests exactly this.
Kassen
