Guest42
Posted: Sat Jan 21, 2006 9:59 pm Post subject:
Buggered Amp! |
Heyo. I wasn't really sure where to post this, but I've having a problem that I'd like to resolve as quickly and cheaply as possible, so hopefully someone can help me out.
I have a GK (Gallien-Krueger) 700RB bass amp. It was working fine for a few days, but after a few hours of having a five string bass plugged in, it started cutting out. Sometimes completely, and sometimes just making the sound barely audible, except for an occasional peak in loudness, which causes the woofers to make a popping sound. It did this even when I went back to the four string.
Turning it off and back on seems to temporarily halt the problem, but it always starts back up, now after just maybe 15 minutes. I took apart the head to find that the fan inside of it does not spin, and I'm thinking it might be over heating. But I'm not sure why it would work sometimes and not others.
Any ideas as to what's wrong and how I might go about fixing it? I am of course going to replace the fan, but I'm not sure that will totally fix my problem. However, maybe someone has had a similar problem which they were able to fix.
Thanks for your time
-Guest42 |
Joined: Apr 03, 2004 Posts: 24653 Location: The Netherlands, Enschede
Audio files: 326
Posted: Sat Jan 21, 2006 10:28 pm Post subject:
Re: Buggered Amp! |
| Guest42 wrote: | | But I'm not sure why it would work sometimes and not others. |
Could be that a temperature protection thing kicks in, this is not uncommon on all kinds of electronics (like power supplies). As air flow and room temperatures will always vary a bit the process might seem random. And after the protection kicked in the temperature would drop and it would switch on again, only to switch of some time later. The 15 min timing you mention could match with that, it's about the time scale I'd expect for such a process.
As long as you didn't replace the fan or made it going again you could try an external fan, like the one you use for yourself on hot days - it would help when the amps enclosure would let air in. I've in used this with success on hot days for halting cumputer equipment :-) _________________ Jan
Posted: Sun Jan 22, 2006 5:17 am Post subject:
I had a problem like this once which was heat related, fix the fan first. You could also find that the heat has made one of the solder joints go dodgy. Without proper ventilation power transistors can heat up to the point where they melt their own solder joints on their leads. If one of those goes intermittent you'll get sudden drop out, and then the transistor will cool, this will move the lead, it will connect and the whole thing starts again. It's relatively easy to check for this as you can unbolt the power transistors from their heatsink and give them a nudge with the power on. If your driver pops (keep the volume down!!) that's your problem. _________________ What makes a space ours, is what we put there, and what we do there. |
Guest42
Posted: Sun Jan 22, 2006 8:02 pm Post subject:
Thanks for the help : )
As far as it being a thermal cutoff, I had thought of that... but then wouldn't it stop playing completely instead of just sounding like a dying old man? I opened up the head, as I've said, but I'm not really sure what a thermal cutoff looks like. Is there a link so I can see what I'd be looking for? |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Sun Jan 22, 2006 8:11 pm Post subject:
tube or solid state ? _________________ Spiral Recordings |
Guest42
Posted: Mon Jan 23, 2006 12:01 pm Post subject:
| It's solid state. |
Posted: Mon Jan 23, 2006 1:02 pm Post subject:
That figures.
The best would of course either let a skilled service engineer solve this for you. If you get a servicemanual it would probably be easy to the most likely spots in the circuitry the problem is located. Isn´t there some sort of basic schematics inside of the cab somewhere? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
deknow
Posted: Mon Jan 23, 2006 1:20 pm Post subject:
...i have blown the "expensive" part of an amp trying to figure a problem like this out...so procede at your own risk.
1. you will need to have a safe way to have the amp on and disassembled (remeber, there is wall current in there).
2. it is probably either a bad solder joint, or a failing semiconductor (transistor, ic, etc). first look at the bottom of board (solder side). if you are sharp (and lucky) you might see the bad solder joint (generally, it will look like there is a ring around the lead (this is actually a crack in the solder, and can fail intermittently with temperature or being knocked around). look at transistors or voltage regulators (3 wires) and any large integrated amp chips (ic's), or any connectors that might see strain (input/output jacks, panell controlls).
2. if you can't see cracks in the solder (use a bright light and magnifying glass), you can get some freeze spray. run the amp until it starts failing, and spray one component at a time with the freeze spray....it should start working again when you get the right component. at that point, you can try resoldering that one component (it might be still be a solder joint), and if that doesn't work, replace the component.
warning, not all transistors of the same type have identical pin outs, so figure out which is the base, collector, and emiter and double check the replacement before soldering it in.
good luck...it feels great to fix gear...but shitty to trash it by screwing up. bring it to a tech if this all scares you, or if you can't afford to mess it up more.
deknow |
