Macaba
Posted: Sat Jan 14, 2006 4:53 pm Post subject:
Tenori-on |
http://www.makezine.com/blog/archive/2006/01/musical_led_panel.html
I rather like this instrument, its extremely intuitive.
I'm thinking to myself 'How is such a project constructed'.
So I put this thread here to facilitate the thinking processes so that perhaps one day we could make a clone of such an instrument, with perhaps more useability (Midi output/CV outputs).
It also in my mind has a very pratical use as a sequencer.
Observations:
16x16 grid of tactile LED switches. Similar to:
http://www.rapidelectronics.co.uk/rkmain.asp?PAGEID=80010&CTL_CAT_CODE=30463&STK_PROD_CODE=M72855&XPAGENO=1
Note that 16 x 16 = 256, which is easily addressable in a 8 bit byte.
I'd like to hear methods of perhaps using a PIC microcontroller to acheive a basic level of functioning. Also- A very cheap source of those switches would ideally be found, so I could afford to build a prototype and experiment.
Sure, it may not be as nice as the Tenori-On, but hypothetical thinking never hurt.  |
Joined: Jan 31, 2003 Posts: 18288 Location: Durham, NC
Audio files: 235
Posted: Sat Jan 14, 2006 8:39 pm Post subject:
Great post. This is very very cool. Be sure to check out the video on the first link. _________________ --Howard
my music and other stuff |
G2 patch files: 626
Posted: Sat Jan 14, 2006 9:30 pm Post subject:
| This is very cute. I thought this post referred to another 16x16 LED controller I saw posted on SynthDIY, but this is different. The other controller was hooked up to a computer display which showed the proximity of fingers as height on a 3D bar graph. So instead of physical switches, it used the LED as a phototransistor during half of the multiplexing cycle. Effectively creating 256 mini d-beams. I guess the two systems could be combined with clever division of time. |
Macaba
Posted: Sun Jan 15, 2006 3:32 am Post subject:
More thoughts:
My guesses/ideas at Basic Modes of Operation
Straightforwards Note Playing:
Its difficult to say how the notes progress over a 2D area. It seems to me that it works extremely similar to this 'theremin' program for the pocket pc:
http://www.pdagold.com/software/detail.asp?s=405
Someone knowledgable suggest how 256 'notes' could be arranged, and how many notes per octave, bearing in mind that its only this mode that will have this arrangement of notes, because other modes are more sequencer style modes
Static Sequencer, Static Time Interval:
The 16 accross is basically a 16-note sequencer. It goes through the notes selected from left to right, at a speed selected when you hold a button on the body and choose from 256 speed settings. (I think this is similar to the tenori-on) You have 16 notes to choose from (Not much, 2 octaves?), but this not neccessarily need to be a inhibition, because another button on the body could allow you to go up or down an octave, select notes to play there, and come back to the main 2 octaves. You just have to remember they are there.
Static Sequencer, Dynamic Time Interval:
The only similarity to the one above, is that it plays the notes where you press them. Everything else is different, and this is how I would describe it: You press a note anywhere, taking advantage of the 256 note range, then you press 2 more notes anywhere. Now, not only does it remember the location of the notes, the ORDER of the notes, it remembers the TIMING between notes. So you could have 2 really quick notes in succession then a low bass note, as an example.
Dynamic Sequencer:
I really rather liked the bouncing sequencer, it looked fun. It seemed to me this is something like how its arranged: The 16 notes accross is the musical range. When you select a height on that column, it starts bouncing at a set speed, and everytime it hits the bottom the note is played. If you press any location in the same column, it just stops that column from playing, and you can press a different height to resume.
Drum Kit:
There are Nth number of circles on the screen (not sure how many drums a standard drumkit has) and when you tap them, it plays that drum. This could be taken further with the 'Static Sequencer, Dynamic Time Interval' principle, in that it remembers the order and timing between notes, so you can get a drum/bass line going.
Synth modes:
This would be taking it to the boundaries, it would be fun to experiment with this. Basically, you select a synth module, and the basic controls for it come up on the screen. You then patch in our clone to a synth and use it as a normal module. Obviously it'll be digital, but the advantage is that you will probably already have the clone connected to the synthesizer to use the sequencer, so to change to a Synth Module mode is just a natural progression. TB-303 mode anyone? This really just depends on programming skill, and effective use of the limited number of switches. (for example: Pots would be represented by 2 switches- Up and Down).
Some ideas there, some derived from Tenori-On and some original ones (or we just havn't seen them on the Tenori-On yet).
To comment on the concept further:
If we were to develop such an instrument, because of its flexiblity, its more suited to professional applications, and its inherant upgradability (just a firmware flash away!) means 'value for money' so to speak. |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Macaba
Posted: Mon Jan 30, 2006 2:03 pm Post subject:
Typical isn't it. I went to my local Maplin (electronics shop) to get a PIC microprocessor to experiment with. They didn't have the one i wanted. The guy suggested I read out part numbers of suitable replacement parts. I read about 8!!! other PIC's, and they didn't have a single one. :S
I've been having a few ideas about interfacing, and I think it isn't too ambitious to set an aim to initially have this as a serial interface instrument for the computer, it certainly allows flexibility. Then i'll look into MIDI IC solutions perhaps after that.
Annoyed about bad electronics shops.  |
Joined: Apr 03, 2004 Posts: 24626 Location: The Netherlands, Enschede
Audio files: 317
Posted: Mon Jan 30, 2006 3:27 pm Post subject:
| Macaba wrote: | | Typical isn't it. I went to my local Maplin (electronics shop) to get a PIC microprocessor to experiment with. |
Farnell ( http://uk.farnell.com/jsp/home/homepage.jsp ) has a large collection of PICs. _________________ Jan
Macaba
Posted: Mon Jan 30, 2006 3:28 pm Post subject:
Thanks for the suggestion, but I wanted to try and avoid the postage that costs more than the PIC itself! :O
I'll try some other contacts.  |
