 Forum index » Clavia Nord Modular » G2 Performances - Noodles
06-004-003
Page 1 of 1 [3 Posts]
PostPosted: Sat Feb 04, 2006 5:58 pm    Post subject: 06-004-003 Reply with quote  Mark this post and the followings unread
In experimental patches the two parts of this were posted already, put it together and tweaked it a bit.
It crackles a bit, guess some fundamental stuff is not quite right, maybe I'll try to find out. Ah well I still like it.
05-004-003.prf2
A voice like thing with a ping
 Filename:  05-004-003.prf2
 Filesize:  15.59 KB
 Downloaded:  2910 Time(s)
Ivity
G2 patch files: 57
PostPosted: Sun Feb 05, 2006 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent noodle Very Happy
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
PostPosted: Tue Feb 07, 2006 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
Here is another go at it, added some space whispers to the cows, and made the echoes a bit less messy.
The cause for the crackling is clear now, removing it would require the classic trick of doubling the delay lines. That would halve the delay times though which spills things and I can't get it to sound the same quite.
So it will keep sounding like an old record is being played :-)
05-004-014.prf2
Another go at 05-004-003
 Filename:  05-004-014.prf2
 Filesize:  18.43 KB
 Downloaded:  2804 Time(s)
