When digital meets analog
Page 1 of 1 [5 Posts]
Axiom
G2 patch files: 28
PostPosted: Mon Feb 13, 2006 11:49 am    Post subject: When digital meets analog
Subject description: How to let your G2 control an old vintage Korg
Today Koney (www.koney.org) gave me an idea about using an a boosted signal coming from a digital synthesizer audio output. I've tried that using my G2X and Korg MS10. The result is very cool. The MS10 responds to those audio signals but the pitch scale come out inverted (a la Joe Zawinul).
Check out those videos:
Video 1: Fist Attempt
This is my first attempt. As you can see, the MS10 Env is totally bypassed using the mod wheel to VCA.
Video 2: G2 Sequence to MS10
Now i'm playing a random sequence generated by the G2 directly into the MS10. Cool, isn't? Wink
Enjoy also the patch used to do those tests. Try it with your analog equipment and post your results. I'm very curious to see what happens on other machines.
Luca
MS10Ctrl.pch2
Patch used to test direct connection between a G2X and an MS10 using nord audio outputs.
 Filename:  MS10Ctrl.pch2
 Filesize:  1.89 KB
 Downloaded:  1742 Time(s)
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
Fozzie
G2 patch files: 49
PostPosted: Mon Feb 13, 2006 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Might check out this thread as well, it will probably be very similar for MS10s and MS20s, only no pitch converter on the MS10 Sad
http://www.electro-music.com/forum/viewtopic.php?highlight=ms20&t=9328
X-Electric
PostPosted: Mon Feb 13, 2006 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
All I can see is a green screen on these videos. I'm on W'2000, using WMP9, and also tried with VLC Player.
cebec
G2 patch files: 31
PostPosted: Mon Feb 13, 2006 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, what do i do? i plug the G2 out into the V/Oct on my analog?
ok, i got it.
this short demo is the patch above with G2 1 out into Evenfall Mini Modular VCO 1 V/OCT. Then G2 2 into VCO 2 V/OCT and VCO 2 is mixed in. Then VCO 2 is mixed out and G2 2 goes into VCF FM and tweaked. Then G2 2 goes into VCO 1 FM and tweaked.
G2 vs. Evenfall.mp3
G2 out signal boosted and controlling Evenfall Mini Modular
 Filename:  G2 vs. Evenfall.mp3
 Filesize:  2.76 MB
 Downloaded:  1857 Time(s)
Audio files: 326
PostPosted: Mon Feb 13, 2006 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
And another one related : : : The Virtual and Real Analogue Project : : :
