Filterbank first attempt....Filterbank first problem....
Page 1 of 1 [3 Posts]
SYnTHaJoY
PostPosted: Tue Feb 21, 2006 1:57 am    Post subject: Filterbank first attempt....Filterbank first problem.... Reply with quote  Mark this post and the followings unread
Hello everybody Very Happy
i just bought my G2...never experienced modular synthesis before...pretty challenging machine Smile i discovered this forum 1 week ago and saw that there is a huge amount of knowledge shared in these pages...hope someone of you can help me out with my first patch development problem....
im trying to build a filterbank up....my final aim is to emulate the famous z-plane architecture...so coombinations of morphing filters..
i would like to control a filter sweep, from HP to LP, with a single knob movement...but i would like the LP filter to start sweepin only when the HP
has finished his job..in order to get the signal unfiltered in the mid knob position...im sure this is easy to get...but as i told u im a complete newbie Very Happy Really hope someone can help me out
Thanks in advance
Matteo
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Feb 21, 2006 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
First post, welcome Very Happy
Sounds interesting.
You can use the minmax module to split a control signal into negative and positive components like in the attached example.
Not sure if it is what you are after.
minmax.pch2
combined low/high filter with sweep
 Filename:  minmax.pch2
 Filesize:  1.13 KB
 Downloaded:  1952 Time(s)
SYnTHaJoY
PostPosted: Tue Feb 21, 2006 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Thanks a lot G2ian!.. that's exactly was i was after...
BTW i managed to go through it in another way..i attach what i got...
in this way u can also have another modulation input if needed...
as soon as i achieve something good enough to deserve a place in this amazing spot i will do it immediatly...
thanks again Very Happy
Matteo
hptolp01.pch2
 Filename:  hptolp01.pch2
 Filesize:  1.34 KB
 Downloaded:  1364 Time(s)
