skylab001
Posted: Mon Feb 13, 2006 11:59 pm Post subject:
Oberheim Matrix 6R problem Subject description: Is my OS Scrambled??? |
I just recieved my matrix 6r and to my dismay when I plugged it in I got
across the entire LCD screen and none of the buttons worked, I tried turning it
on and off
again a couple times and nothing but the same @@@@@@@@@@@ all the way across the
screen. I then tried hooking it up to my midi controller to see if I could get
any sound and
nothing. I ran through every midi channel and nothing worked. I then looked a
little closer
and noticed a few screws missing on the case so I went ahead and removed the
top, when I
noticed that a cable that looks alot like a standard IDE cable(with 3 connection
points) was
disconntected. I proceeded to plug it back in but it didn't help at all. I
also checked to see if
all cable harnesses and chips were seated properly, which they seemed to be.
Has anybody here ever checked out thier M6 or 6r(is that really an IDE
cable....wish I had a
picture of the insides of this thing)....and has anybody ever experienced this
problem? Maybe
know how to correct it. I'm guessing the Rom chip may be messed up...but that
is just a
guess.
Brian |
Joined: Jan 31, 2003 Posts: 18266 Location: Durham, NC
Audio files: 229
Posted: Wed Feb 15, 2006 6:29 pm Post subject:
I don't have a 6R, or any Oberheim gear. It sounds serious. Good luck. _________________ --Howard
my music and other stuff |
skylab001
Posted: Sat Mar 18, 2006 1:07 am Post subject:
just an update...turns out when it was shipped, fed-ex dropped it..... .........and bent one of the rack ears and dislodged all connections on the internal ribbon cable. I had originally found the one on the main board but there is one that is slightly out of site under the LCD board.....when I found that I turned it on and all was well
So this is now the second item fed-ex has dropped, that was after UPS dropped a couple too.....and you think they'd be a little more careful
Oh well It works so I'm happy! |
Joined: Apr 03, 2004 Posts: 24524 Location: The Netherlands, Enschede
Audio files: 299
Posted: Sat Mar 18, 2006 8:19 am Post subject:
| skylab001 wrote: | So this is now the second item fed-ex has dropped, that was after UPS dropped a couple too.....and you think they'd be a little more careful
{rant}
From where I work I've got a good view on the way packages are picked up (and I'm wel hidden from view). They are never dropped, but thrown, the lighter the package the further it's being thrown. It's just laziness to walk the last few meters, or to step into the truck. Then they drive away and I can only imagine what happens at the fist bend
{/rant}
| Quote: |
good ! _________________ Jan
