toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Mon Mar 20, 2006 3:13 am Post subject:
caveman I.C.s! |
the following was cutted and pasted from the other thread....
~also, i have decided to make two 3-LDR/1-LED, [a la 'hairball']
controls to at least test my idea of the 'spread' control dynamic of the synbal circuit. which i think [i hope] will be interesting enough to do. my plan is to inversely shift the frequency of the 3 highest and lowest oscillators... a la 'hairball crossfade circuit' with control voltage.
when the top 3 are getting higher, the bottom 3 are going lower, and vice-versa. also, the topmost osc will be affected more than the one below it, and so on... same for the bottom 3, where the lowest in freq. will be affected more than the others. this would be alot easier to diagram than write about!
i think it will definitely be good to have at least 4 different tap-points of this configuration brought out to a mixing section, maybe a matrix style mixer? or a joystick... hmm.. maybe thru simple bandpass filters. wow this just got alot bigger of a thing... sorry to ramble on as much about an entirely different project, ill keep y'all posted~
as promised, im keeping you posted. i couldn't resist... it's 5 AM im going to bed but i just finished 2 caveman vactrols, and here are pictures taken by a shitty camera. enjoy!
Description: |
Filesize: |
27.22 KB |
Viewed: |
9278 Time(s) |
Description: |
Filesize: |
21.96 KB |
Viewed: |
9279 Time(s) |
Description: |
Filesize: |
20.64 KB |
Viewed: |
9277 Time(s) |
Posted: Tue Mar 21, 2006 12:40 am Post subject:
Cool!
I love the look o' dem chips!
Guitarists have known for ages that a beautiful instrument looks as cool as it sounds. You're (in fact we are all) doing the same for the electronic music world!!  _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Mar 21, 2006 1:53 am Post subject:
Great looking DIY Vactrols!! What did you use as the coating?
(It's just that it looks like that 'sticks like s**t' stuff (no more nails) you can get from DIY shops. If it isn't, I apologise- but if it is, are you using the solvent-based version or the water-based one? (the latter is better imo- because it isn't poisonous!!)) _________________ ACHTUNG!
mi_dach
Posted: Tue Mar 21, 2006 3:44 am Post subject:
Ha!
these things are absolutely awesome, thanks, you've made my day  |
toppobrillo
Posted: Tue Mar 21, 2006 6:23 pm Post subject:
hey thanks guys! the coating i used is an air-dry modeling clay, i used the inside of a thimble as a kind of mold. i am making more of these in the vtl5c2/3 configuration too soon.
josh |
Scott Stites
Audio files: 96
Posted: Tue Mar 21, 2006 8:14 pm Post subject:
Whoa, extremely kewl opto-couplers there!!! Me like
A friend of mine did this a while back. He measured the components out carefully, put them together and......didn't work. Didn't work quite badly, actually.
He finally figured out the potting compound he used was conductive
Ouch!!!
Cheerio,
Scott (finally going home tomorrow) |
Posted: Wed Mar 22, 2006 2:50 am Post subject:
I got 8 LDRs today and plan on building some mutant "vactrols". They have a dark resistance of over 1M and an "under a lamp" resistance of about 3K. Does this sound good? What is the schematic for the filter you're working on Scott? What is the vtl5c2/3 configuration? _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 96
Posted: Wed Mar 22, 2006 6:53 am Post subject:
Hey Uncle K,
Mutant Vactrol Filter schemos can be found here:
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id17.html
I think your optocouplers will work fine - perhaps a little darker sounding (I think the min resistance of the VTL5C3/2's I used go a bit lower in resistance). You can always try swinging the cap value a little lower to brighten it up if you need.
Take care,
Scott |
