A patch for Jan Punter.
Page 1 of 1 [11 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Mar 24, 2006 8:21 pm    Post subject: A patch for Jan Punter. Reply with quote  Mark this post and the followings unread
A patch for Jan.
/Dasz
JPunter2_DZ.pch2
JPunter_DZ for Jan Punter.
 Filename:  JPunter2_DZ.pch2
 Filesize:  9.21 KB
 Downloaded:  1736 Time(s)
PostPosted: Fri Mar 24, 2006 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm honoured, thank you Very Happy
It is subtly playable from the computer keyboard, using keys 1 .. 8, and ctrl+z will play the tweaks backwards Exclamation
TheRain
G2 patch files: 9
PostPosted: Fri Mar 24, 2006 9:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Three cheers for Jan! And also for dasz... Wink Smile
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Mar 25, 2006 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad you like it! It's just a start. Lots of sequencers for more complex melodies. Use the 4 switches to include or exclude. I did not tune all the variations, thus they sound simillar. Like I said it is a start!
And randomization for turning the phrases on and off. I think the place to do more work in is how the seqeuencer signals interact with each other (right now they are added together). I'm thinking using randomization to decide whether to play some of the sequencers, as well as using randomization to determine how their signals are mixed (added, maxmin, delayed and addedm etc).
The basic simple noodle essentially, thus a patch for Jan!
Up to now, my stuff has always been controlled and NOT randomized. I have to start using that tab for things.
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Mar 25, 2006 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
and another version, more tweaking.
This one is even more happy than before Mr. Green !
/Dasz
JPunter3_DZ.pch2
Jan Punter patch v3
 Filename:  JPunter3_DZ.pch2
 Filesize:  9.21 KB
 Downloaded:  1676 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Mar 25, 2006 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
and another one. This is fun! It needs more randomization.
These patches open in the demo version. But on my pc, it opens
and the background behind the word Mono is red and nothing is playing.
This sucks.
Can someone else try to see if this is a bug? Hopefully this is cuz, my
pc is too slow.
/Dasz
JPunter4_DZ.pch2
 Filename:  JPunter4_DZ.pch2
 Filesize:  9.32 KB
 Downloaded:  1757 Time(s)
Audio files: 235
PostPosted: Sat Mar 25, 2006 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
pc is too slow.
/Dasz
This patch runs fine on my G2X but doesn't work on the demo software, just as you describe.
PostPosted: Mon Mar 27, 2006 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Variation 5 of nr 4. is pretty good ! Its just the right mix of sadness and happiness, the one that makes you cry with a smile ...
Added a tiny bit of swing to it, would be fun to mess with the sequencer lengths a bit in this one as well.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Fri Apr 14, 2006 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
pc is too slow.
/Dasz
Ok, I have figured out why this patch won't open.
Apparently the demo version can only open up a patch that uses 100% summed (ie a single DSP). My patch was almost 100% in VA and 100% in FX area. The combined Load ofVA+ FX cannot exceed 100% in the demo.
Just something I came accross while playing on my new laptop!
/Dasz
cebec
G2 patch files: 31
PostPosted: Fri Apr 14, 2006 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice sounding patches, dasz!
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sat Apr 15, 2006 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks cebec...
/Dasz
