guitar_player
Posted: Fri Mar 10, 2006 4:31 am Post subject:
Question about Roland td-3 drumset |
Hi! Three days ago i've bought a new drumset Roland td-3 kv. It costed 1150 euros. It's great.
I'm really happy. I can play at home! I have a question: how to connect additional sounds
to my td-3 module. One forum (http://drumset.bravehost.com) says, that it's possible, but i don't
how to do it. |
Posted: Fri Mar 10, 2006 7:36 am Post subject:
That dumset.bravehost thingie isn´t a forum. What I am seeing is this:
I am pretty sure you are seeing the same. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Joined: Jan 31, 2003 Posts: 18260 Location: Durham, NC
Audio files: 228
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Sun Mar 19, 2006 8:53 pm Post subject:
you will need a Roland Trigger-->MIDI convertor.... _________________ Spiral Recordings |
opg
Joined: Mar 29, 2004 Posts: 954 Location: Berkeley, CA, US
Posted: Mon Mar 20, 2006 7:09 am Post subject:
Not possible with any drum brain. This is one of my biggest pet peeves (why didn't I mention it in the Pet Peeve thread?). You'll need a trigger to MIDI convertor like paul said, and then connect it to a sampler or your computer.
Or you could try to build a drum brain / sampler and then brag about it for months but never actually quite finish it like I did.....
Seriously, everything is finished except for the code for the GUI and a USB input. So far, you have to load sounds via a serial port.
http://27b-6.lathan.org |
mi_dach
Posted: Mon Mar 27, 2006 4:14 am Post subject:
trigger-midi converter |
| opg wrote: | Not possible with any drum brain. This is one of my biggest pet peeves (why didn't I mention it in the Pet Peeve thread?). You'll need a trigger to MIDI convertor like paul said, and then connect it to a sampler or your computer.
If using a trigger->midi converter, and samples on a computer, how much latency is acceptable in the system? I tolerate 10ms on my guitar, but Im wondering if that much would totally destroy the feel of drumming? |
opg
Posted: Mon Mar 27, 2006 7:35 am Post subject:
| I have a very low latency on my computer, and I have a Dell with a Pentium 4 (definitely under 1GHz), 512 MB of RAM, and a M-Audio Audiophile 2496 sound card. It works perfectly, and I'm not even using real electronic drums - just some that I built with triggers, mousepads, and PVC. |
