hanging G2 with Machinedrum as clockmaster?
Post new topic   This topic is locked: you cannot edit posts or make replies. Moderators: Nord Modular Editors
Page 1 of 1 [2 Posts]
3phase
G2 patch files: 141
PostPosted: Mon Apr 03, 2006 5:45 pm    Post subject: hanging G2 with Machinedrum as clockmaster? Reply with quote  Mark this post and the followings unread
I run lately into more and more hangs with my G2...
it seems to be related to certain patches...but than it works again...or just happens on patches that never made problems before...Just an idea that certain patches are more likely to hang..the last realtime sequencer i posted here was hanging often for example..but during patching i played it for hours without a hang... Only when the machinedrum is clockmaster it happens...At least i got that image...but than i had a hang without the machine drum... so i can only say that statistically it happens much more when the machinedrum is master...not enough to point to the source of the problem.
I was thinking about sending the machine in for service but cant afford that timewise in the moment...
What makes me currious is that it all started happening the day i bought the elektron machinedrum...
Are others have similar issues so that we might present it as a bug to clavia?
With me the leds from the patch selector buttons are freezing an no sound gets out of the machine...forcing a recompile clears the situation, but i had situations where i had to do a cold start to get it working again...
I mailed clavia about it allready but the answer just was that they dont think that its a hardware problem, or see this as the least likely source of the problem, but also dont have a reproducable software situation with my problem so there was no advice what to do..
I rather would like this to be investigated before sending my G2 without good purpose all the way to sweden...
So question... HAve any other users experianced a hanging g2 ?
and what was the configuration when that happened?
I can say it only happened with the MD as clockmaster sofar...
with my G4 powerbook as clockmaster there was no hangs...
And thats a pitty beecause it grooves better with a jitterfree clock from the MD...especially because the MD soundengine is pretty late in relation to the nord..
attached patch like to hang on my G2 with the MD as clockmaster
LXP5 Tout.prf2
 Filename:  LXP5 Tout.prf2
 Filesize:  21.47 KB
 Downloaded:  1422 Time(s)
PostPosted: Mon Apr 03, 2006 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I'll leave this post here as maybe it will indeed get more attention this way. However to avoid the discussion to get scattered I'll lock this thread. The isssue can be discussed at http://electro-music.com/forum/post-73476.html there already are some items there.
