a must-read for beginner computer musicians
Page 1 of 2 [41 Posts]
destroyifyer
PostPosted: Thu Apr 20, 2006 10:39 am    Post subject:  a must-read for beginner computer musicians
Subject description: read this if you are new to computer recording!
I have literally lost 24+ hours worth of music (yes a whole day of music). this happened when I deleted the music after I made a backup CD...well guess what the blank CD used was total crap, and almost a year's worth of electronic music went swirling down the toilet. yes i know it sucks.
But that's OK. old music sucks anyways. It just inspired me to make new music. It was like some diety trying to tell me, "Teradacto, thine music blows. Make new music."...
But others might not feel the same way about their hard work. So be quite careful, with your backup and recording methods.
So if you are new to computer music, then definately beware CD backup...it's not as dependable as it seems. Just never delete music before you check to see it's safe and sound.
Also, be very careful how you record on a computer! DEFINATELY run tests before you record, and make sure there are no beeps, cliks, or bumps bugging into your music. Not to sound like a pompous ass or anything, but I have made some very awesome music that accidently got turned into unrecognizable garbage by sloppy recording.
p.s. "Sound recorder" rules...I think that songs sound great on 48000 HZ's on sound recorder. But you just have to be careful with your frequencies. Recording from a lower to a higher frequency or vice-versa can really mess up your song. Also, it's a good idea to un-plug your microphone and line-in if you aren't using them, just so you don't get any little feedbacks. Another beware, a song might sound fine when you're recording it, but it might actually be getting distorted to crap if your playback volume is low. I could go on, but
I'll just shut up now
Love, Teradacto
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 20, 2006 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for reminding us of the "art of backup" Exclamation
PostPosted: Fri Apr 21, 2006 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
When failure is not an option:
http://www.quantum.com/Products/TapeDrives/Index.aspx
Ok, ok. Shamless plug. But tapes will last for 30 years easy, and will tell you if & when they don't write properly. Assuming you've got it on the hard drive first....
destroyifyer
PostPosted: Fri Apr 21, 2006 6:31 am    Post subject: a
Subject description: a
Yeah this "tape backup" is totally new to me...I mean, things will never be the same between me and CD-R's...I just look at them with the most bitter, chilling feelings shooting down my spine.
PostPosted: Fri Apr 21, 2006 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Tape back-up is cool. Big enough to leave on while you do the hard work- ie going to bed and sleeping a bit Very Happy Cool
ACHTUNG!
PostPosted: Fri Apr 21, 2006 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
What does a tape backup solution cost? Are there any low-budget alternatives? I remember 10 years ago hearing about using your VCR together with some Amiga interface to make backups on VCR tape...
/Stefan
PostPosted: Fri Apr 21, 2006 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I remember seeing someway of backing up to Mini DV tape too- via your camcorder and a firewire connection.
Anyone else seen this? I'll google it.
ACHTUNG!
PostPosted: Fri Apr 21, 2006 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Here;
http://www.coolatoola.com/
It's for Mac- but I'm sure there will be 10 PC versions to take its place Razz
ACHTUNG!
PostPosted: Fri Apr 21, 2006 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
For what's called the mid-range tape drives, they are ~ $3,000US, $90/tape. These are the DLT-S and LTO drives. Ok, stop choking. If I had a busy studio, I'd invest in one of these, since in the end, it costs 6.5cents per GB. One 4" square tape can hold over 1TB, which is enough room for every project, take, track, DVD, CD, super-CD, and web formats for an entire album, along with all the pictures & video taken while in the studio Smile
The next level is the DLT-V, which is ~$600-$1,000, $50/tape. 160 - 320GB per cartridge.
Then you hit DDS ($500), <100GB/tape.
Last is Travan, the cheapest. They're 20GB/tape, for ~$130US, $30/tape. That's probably the most realistic for anybody's home use, and it's still 3x a DVD dual-layer, and can be used a few thousand times.
When shopping, you'll notice some are listed as 20/40GB. the first number is usually the raw data the tape can hold, while the second number is with compression turned on. Most tape drives these days have a hardware compression chip, and it's foolish to turn this off, since it guarantees that you'll get at least 1x, and if you're lucky upwards of 4x compression. Most audio (NOT .mp3, but .wav, etc) will compress ~1.5-2.0 (up to 1/2 the size). Any file already compressed, won't shrink much (.mp3, .jpg, .zip etc). The low end drives (travan) will probably do this in software, making your backups & restores take longer.
PostPosted: Fri Apr 21, 2006 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, thanks.
Browsing for Travan I stumbled across a local Mac merchant on the net. Under the heading "tape station" they had Iomega REV 35/90GB FireWire, which costs 2795/400 SEK which is roughly (sleepy currency translation in my head) $350/45. They claim it is more reliable than older tape solutions...
Rolling Eyes
It seems to be Mac only, which is OK by me since I am a proud owner of a MacBook since a day ago Very Happy
/Stefan
bachus
PostPosted: Fri Apr 21, 2006 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I’ve had professional experience with tape backup (long time ago admittedly) but I can assure you they are NOT guaranteed security. And you still must use a three tape rolling backup and replace the tapes regularly which is quite costly. AFAIK The advantage of tape is not that it is more reliable, it’s that they can backup entire HDs as a single image.
I use DVD backup, though CD is probably safer. The “Shadows of War” piece was 2+ gigabytes so DVD was the only reasonable choice. Only use a backup program that verifies the backup. Backup your work at least once a week preferably more. I bakup on to a second HD on my computer daily (Raid 1 is a better approach) and onto DVD weekly. Retain at least the 4 most recent backups. I.e. don’t’ use RW media. Chances are extremely good that at least one of those backups will be OK. If you backup weekly you will loose no more than a months work worst case at near astronomical odds – assuming that you do in fact use a program that does a read-verify after write. Once a project is complete you can make two or three copies on gold archival CDs or DVDs.
Anyway that’s what I do and would recommend. What do think mosc?
PostPosted: Sat Apr 22, 2006 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Tape drives today don't use ferrite heads anymore, they use magneto-resistive elements, so the read & write heads have to be seperate. Because they *have* to have seperate elements, drives will check the data as it's being written. Because MR heads are so much smaller, most drives use at least 2, if not 4, 8 or 16 tracks. So more redundancy is built in, and the built-in error correction schemes used leap frog off of this fact. Point is, tapes have gotten very reliable, as long as you take care of the tape Smile So follow the instructions on tempurature & humidity, because they are 2 very big factors in how well a tape survives, along with your data.
I don't think any Travan would be limited to "Mac Only". Supporting that market would be way too small for any tape drive company to survive doing. The software doing the backup, and hence the data on the tape would only be accessible via MAC (and micr$oft does the same thing).
Audio files: 235
PostPosted: Sat Apr 22, 2006 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Lot's of good advice here. No backup scheme is any good if you don't use it. If you are going to rely on tapes, the you must have the decipline to do the backups regularly. I'm too disorganized and lazy to use tapes. I rely on RAID. RAID is good at protecting you againts a drive failure, but you could get wiped if your RAID controller goes south. It can write garbage over all of your drives and you'll loose all your data. This is rare but I've seen it happen on some big Sun systems.
So, I use RAID and I copy my stuff over the network to a second computer running RAID. I use a Unix program called rsync to do this. It only copies files that have been modified. I run it automatically. This is pretty good protection as long as your house doesn't burn down. Moving your backups offsite - either by mailing tapes or DVDs or by network transfer - is important if you want to assure against almost all possible catastrophies. Of course, there is not much you can do if the Earth is destroyed.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Apr 22, 2006 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
what's wrong about the south Question are you feeling mooshadda or stoonad Question
arrow Italian-American Slang
PostPosted: Sat Apr 22, 2006 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
in this context south is kinda like down the drain, up shit creek, into the volcano, off into space, departed and so forth..
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Apr 22, 2006 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh, I see. I thought it was a racist remark Wink just kidding Rolling Eyes
PostPosted: Sat Apr 22, 2006 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
nah.. it´s more like kinda mixing up geography with death...
I guess we have been talking too much about norwegian food
Flickr
PostPosted: Sat Apr 22, 2006 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-10756.html
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Apr 22, 2006 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
without the help of mass quantities of aquavit Cool
PostPosted: Sat Apr 22, 2006 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes indeed, I have made the same observation myself.
Flickr
bachus
PostPosted: Sun Apr 23, 2006 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh! Is that what aquavit is for? Now I understand the high rate of alcoholism in that part of the world.
Audio files: 235
PostPosted: Sun Apr 23, 2006 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, it may not be racist, but it is certainly regionalist. I was born in the south, so I feel it's OK to use the term.
Hmmm... Nowadays, the South has more northerners living there than southerners. This must be because the South is more desireable than the North. So maybe, over time, the expression sould be, "Shit, my RAID system went north!" Shocked
PostPosted: Sun Apr 23, 2006 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Keep in mind that skillfully handled, aquavit will make sure that there is no major difference between north and south, up and down, east or west. Take care though, aquavit can also remove paint from furniture and dissolve several types of glue.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Apr 23, 2006 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
it makes even lutefisk edible Shocked
PostPosted: Sun Apr 23, 2006 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
True!
Flickr
