today> Twyndyllyngs - canceled because of back pain - sorry Chez Mosc
 Forum index » Instruments and Equipment » MAX/MSP - Pd
c-cut (simple rhythm sampler)
Page 1 of 1 [2 Posts]
Ivity
G2 patch files: 57
PostPosted: Fri Jan 20, 2006 11:19 pm    Post subject: c-cut (simple rhythm sampler) Reply with quote  Mark this post and the followings unread
This is very simple rhythm sampler, which can generate (manually or auto) rhythm patterns. All you need to do is to load any sample, to cut it into sections (manually or auto) and to draw rhythm pattern using two matrices. For patch testing there are loop sample in the archive. I did't use any amplitude envelopes in the patch, so it can output "clicky sound".
C_CUT.ZIP
 Filename:  C_CUT.ZIP
 Filesize:  254.58 KB
 Downloaded:  538 Time(s)
Alexander
G2 patch files: 4
PostPosted: Wed Apr 26, 2006 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
This looks and sounds good! I will have to check out the patches in depth, but so far thumbs up!
