Pitch Bend Question (NM1)
Page 1 of 1 [7 Posts]
Repeatpeak
PostPosted: Sun Apr 02, 2006 3:11 pm    Post subject: Pitch Bend Question (NM1) Reply with quote  Mark this post and the followings unread
Was wondering if someone here knows how to solve a pitch bend issue I'm having with the NM1.
In addition to using the keyboard I also trigger sounds in the Nord via a pitch-to-midi guitar converter. This works well but the pitch bend range in the Nord seems to only affect pitching up, not down. This becomes a problem with faster movements and sliding downwards on the neck. I don't have this problem on most other synths where the Pitch Bend range parameter defines both pitching up and down. At least that's my assumption of what causes the problem in the NM1.
I would be glad if anyone has an idea of a workaround or perhaps a setting I haven't noticed!
Philip
Repeatpeak
PostPosted: Wed Apr 05, 2006 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Does anybody know what might cause this problem? I have run into several synths that show the same issue while others work perfectly OK.
Among the synths that work fine are:
- Waldorf microQ
- Terratec Komplexer (VSTi version of microQ)
- Z3TA soft synth
Synths that have the pitch bend problem when using a guitar-to-midi interface:
- Nord Modular classic
- Absynth VSTi
- NI Pro53 VSTi
Even if people here don't encounter the problem when using a keyboard, I'd be very glad to even get a clue of what might cause the pitch bend problem with my guitar-to-midi interface. Again, my assumption is that pitch bend range is defined in some synths for only an upwards direction, which casues the glitches in pitch when playing downwards movements.
Thanks for any ideas and feedback!
Philip
elros
PostPosted: Fri Apr 07, 2006 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll see if I can hook up my Micro Modular to my Roland GR-20 this week-end, and see what the pitch bend does.
Audio files: 309
PostPosted: Fri Apr 07, 2006 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
For my MIDI sax it is a configuration option to have pitch bend work in one or in both directions. It "should" work in both, but that's harder to play as you'll need better control over lip tension. I used both options with the NM Classic so I'm pretty sure it can go both up and down.
Repeatpeak
PostPosted: Mon Apr 10, 2006 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I use a GI-20 with the Nord Modular classic as well and would be very curious to hear if you get it to work well.
The bend problems occur when I play downwards scales or slide down from a note.
Thanks
Philip
elros
PostPosted: Mon Apr 10, 2006 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried it last night, with my GR-20 and my fretless bass. The Micro Modular does pitch bend both down and up. I set the pitch bend range to 12 semitones on a simple patch with one VCO, a filter and a VCA. It reacted to sliding down and up a full octave, no problem.
I imagine that your GI-20 might be set up to not send pitch shift down. But then why does it work with your other sound generators?
Shocked
I don't know. I do know that the pitch bend information sent from my GR-20 depends on the patch selected. A piano patch, for example, won't do pitch bend; while a trombone patch will.
Repeatpeak
PostPosted: Sun Apr 30, 2006 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the late reply - I was on vacation for a few weeks.
Thanks, Elros, for trying this out with your GI-20 and Nord Modular! Highly appreciated!
The GI-20 seems to only have a general Pitch Bend Range parameter and doesn't allow separate up/down values. I guess that means I will have to look deeper into the patches I'm playing on the Nord Modular and see how I can adjust them to work better.
Thanks again for testing this!
Philip
