two filters
Page 1 of 1 [2 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Fri May 12, 2006 2:31 am    Post subject: two filters
Subject description: filthy filter and morphing filter
As the title says, two DIY filters.
The "MorPhilter" is allows continuous dynamical morphing from 24dB-LP (-64) to 12/12dB-BP (0) to 24dB-HP (+64) characteristics. Nothing special otherwise, just an exercise with poles and phase relationships.
The "Filthy Filter" uses the Resonance Mod input of the NordFilter module to add odd harmonic distortion to the resonance. This is neat, cheap, and doesn't seem to need integrating mixers to stabilize the high frequencies -so the filter keyboard tracking remains intact too. But note that this only works properly when the filter gain control (GC) is turned off, and the filter type is set to LP. The 24/12dB option is available, though.
Also, since this circuit is compressive, it is input-sensitive. If you max out the resonance, but drive the filter input very hard, you'll won't get much of a resonance peak. Back the levels off a bit for more reso peak.
best,
tim
MorPhilter TK.pch2
dynamic LP-BP-HP morphing filter
 Filename:  MorPhilter TK.pch2
 Filesize:  1.48 KB
 Downloaded:  1612 Time(s)
FilthyFilter TK.pch2
filter with odd harmonic distortive resonance -"dirty" sound
 Filename:  FilthyFilter TK.pch2
 Filesize:  1.96 KB
 Downloaded:  1667 Time(s)
cebec
G2 patch files: 31
PostPosted: Fri May 12, 2006 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice, tim, thanks!
