Experiment with scales
Page 1 of 1 [5 Posts]
PostPosted: Fri May 12, 2006 11:56 am    Post subject: Experiment with scales Reply with quote  Mark this post and the followings unread
Used SeqCtrl modules as lookup tables to implement two pentatonic scales. I'm not sure I did everything right, but thought it to be giving interesting results.
The idea is that two partial quantizers and a subtraction can implement fractional note values like 9/8, 5/4 etc. In http://en.wikipedia.org/wiki/Pentatonic_scale (the Tuning paragraph) I found two sequences of fractional note values that I implemented in this patch.
(1/1, 9/8, 5/4, 3/2, 27/16) and (1/1, 9/8, 21/16, 3/2, 7/4)
Variation one has the first sequence, variation two the 2nd, both expanded to two octaves (but that could be done in a more general way - left as an exercise for the reader).
I made the patch to auto toggle between the two sequences, which is making it interesting to me.
The top sequencer has the numerator and the bottom sequencer the denominator of the fractions. That is, one less than than the actual values (and that's the part I'm not quite sure about).
Anyway, it sounds good enough to me :-)
012-002-001.pch2
 Filename:  012-002-001.pch2
 Filesize:  4 KB
 Downloaded:  2917 Time(s)
PostPosted: Fri May 12, 2006 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or a variation, some nutty chinese noodle restaurant.
06-012-004.prf2
Chinese restaurant noodle
 Filename:  06-012-004.prf2
 Filesize:  13.63 KB
 Downloaded:  2937 Time(s)
eposk
PostPosted: Sat May 13, 2006 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
nice noodle! mmm soy sauce.
mother misty
G2 patch files: 130
PostPosted: Mon May 22, 2006 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan!
I really like that first one.
Sounds great, very organic!
PostPosted: Tue May 23, 2006 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks mother !
