G2 engine midi clock twice as fast as I want it
Page 1 of 1 [6 Posts]
carlitos1
PostPosted: Sat May 13, 2006 1:41 pm    Post subject: G2 engine midi clock twice as fast as I want it
Subject description: G2 engine midi clock twice as fast as I want it
Hi
I am on Logic 5.5.1 on PC and the sequencer on the G2 is going at twice the rate of its MIDI clock. The master turns red and off the scale above 150 bpm. Not had this long and I am stumped! Seems to be on all patches. Logic is set up fine. MMMmmmm dont think that there is a PPQN setting in Logic?
PostPosted: Sat May 13, 2006 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't really help you with your problem, but still wanted to say welcome
In general it seems better to sync software from the G2 and not the other way around, well that's what most people say, never tried it myself.
carlitos1
PostPosted: Sun May 14, 2006 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I have read this elsewhere on the forum, and I will try this but, even if that is a better way its dose not seem a more convenient way as i would have to start the nord each time I wanted to just start the sequencer. I am sure that a basic clock should work anyway even if its not spot bollock accurate. I would like to solve this one even if I do use another technique later on as it is just not the way it should be.
Calude Voiot
G2 patch files: 5
PostPosted: Sun May 14, 2006 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
An idea
Although I dont know logic I would suspect some kind of midi
clock loop.
is G2's midi out connected to the computer's midi IN
If yes check the thru/merge setting in logic
Calude
carlitos1
PostPosted: Mon May 15, 2006 10:09 am    Post subject:   Reply with quote  Mark this post and the followings unread
Solved it. NOW I am in sync! On logic 5.x you need to set (in the AUDIO synchronization page) "audio sync mode" to anything but continuous. At last my LFOs and triggers are finally in time though. Not tried any percussion yet but if I fly in the parts as audio and then sort out the spot bollock timing there that will be cool enough.
When I had a go at syncing logic to the G2 although the timing seemed "OK" it was maybe a bit "soft" the tempo going up and down in the read out slightly was a bit un-nerveing. So I will stick to syncing the nord like this for now. Fine for LFOS envelopes delays ect
Thanks
Carl
PostPosted: Mon May 15, 2006 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad you solved it !
I'll make a link to this from the FAQ.
