Harmonic Motion
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed May 24, 2006 3:08 pm    Post subject: Harmonic Motion Reply with quote  Mark this post and the followings unread
Someone posted an interesting link on the mailing list.
I had to try this, only 14 sections (thats how many voices my piano patch gets) you could expand if you go simple tones or external midi.
I use the sine frequency doubler trick to get 2,4,6,8,10,12,14th harmonics,
The rest are synched LFOB's
harmonicMotion.pch2
simple harmonic series triggers notes
 Filename:  harmonicMotion.pch2
 Filesize:  5.13 KB
 Downloaded:  1888 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu May 25, 2006 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a really nice version of it g2ian. It's really cool how it seems to move through different chords, and those note clusters seem to hit at just the right time.
I love it when mathematically generated music sounds really nice Very Happy Something about a formula generating beautiful music is really really cool.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sun May 28, 2006 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Afro
It occurred to me that my first attempt, using frequency multipliers, might not be the best way to get the end result.
This perf has a version that starts with a high frequency clock and divides down by big-ish ratios. Like the way DCO's work.
Managed to get most of the first 12 harmonics from one master clock, 7th is not perfect and 9th is missing but the rest are bang on.
This technique also makes syncing to other elements more practical than the first.
The RndClk and LevAdd in the top right provide dynamics and pause the note stream.
harmonic-1.prf2
another way
 Filename:  harmonic-1.prf2
 Filesize:  8.92 KB
 Downloaded:  1870 Time(s)
