1/4" to rca or buy an rca soundcard?
Page 1 of 1 [7 Posts]
xena
PostPosted: Thu Jun 15, 2006 1:18 pm    Post subject: 1/4" to rca or buy an rca soundcard? Reply with quote  Mark this post and the followings unread
I need to plug Two RCAs (in+out) into my PC. I`m using Soundblaster Live! Platinum, and I want to replace it with something like MAudio 2496. But i`m considering also something like Behringer FCA202 wich has all PL 1/4" connectors (or maybe a more expansive maudio card)
Should i stick to cards with RCA or there is a good with no lose way to go from PL to RCA?
PostPosted: Thu Jun 15, 2006 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
May I ask which external devices your are going to connect to your computer?
xena
PostPosted: Sat Jun 17, 2006 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Video (vcr and cables audio).
dnny
PostPosted: Sun Jun 18, 2006 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
are you going to circuit bend some video equipment?
if not, i don't see why this topic is on circuit bending forum.
i will move it to: Instruments and Equipment > General Discussion
www.koelse.org
flickr: cable porn group
xena
PostPosted: Sun Jun 18, 2006 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
This is where it was. someone moved it here.
dnny
PostPosted: Sun Jun 18, 2006 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked ok Question
anyway welcome to electro-music forum
www.koelse.org
Audio files: 232
PostPosted: Sun Jun 18, 2006 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I would go with something with 1/4" connectors instead of RCA because in my experience 1/4" are stronger connections. You can always use a 1/4" to RCA adapter. If you have RCA jacks, you can also use an adaptar but these tend to hang on the jack because of the weight. Most synt gear uses 1/4".
RCAs are used in places where the connections are not intended to have may insert/removal cycles, like on consumer-grade stereo equipment.
