I just took apart an upright piano and
Page 1 of 1 [5 Posts]
opg
PostPosted: Tue Jun 20, 2006 5:54 am    Post subject: I just took apart an upright piano and
Subject description: now the SoundLab pops into my head
My mother-in-law moved to South Carolina and we had no choice but to take apart the upright piano to remove it from the house. We didn't think anyone would take it away themselves since we painted cartoons and animals all over the piano. Besides, all three pedals and at least two hammers needed to be repaired. Nevertheless, I had an exciting time taking this thing apart!
The rack of hammers inside slides right out after removing 4 screws. The keyboard was removed by unscrewing 6 screws. Unfortunately, I couldn't remove the soundboard/strings/plate from the back of the piano (which may have been the most valuable part in the long run).
I have seen Ray Wilson's bass pedal schematics for the SoundLab
http://www.musicfromouterspace.com/analogsynth/footpedals/footpedals.html
but I am not sure about how to set the keys so they rest in the up position. When in the piano, the rack of hammers rests on the back of the keys, keeping them in the "up" position. So, when I removed the keyboard, the keys lay flat. This is one extra obstacle after being intimidated by the massive resistor matrix that needs to be created. Shocked
By the way, I am not planning on using all 88 keys. I am not insane. No. Definitely not. Three octaves should be the max. However, I was thinking about what two SoundLabs connected to a mixer would be like (perhaps only one being controlled by the keyboard - I haven't really thought this through yet). Definitely not insane.
PostPosted: Tue Jun 20, 2006 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi opg,
there's nothing insane about going all out for the sake of electronic art! Just don't take on too many projects that can't be completed in less than 2 weeks. If you do, you'll soon have heaps of half finished things laying around and nothing to show off how much of a genius you are!! Wink Yes, I know this from experience.
First look at how you would mount the keys in a case of some kind. The way of pulling them up should be more clear then. Same with the method of switching. Ray used reed switches. Check out micro switches as well (although they could be expensive)
opg
PostPosted: Tue Jun 20, 2006 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I was going to use the original wood case that the keys are in, but just shorten it to three octaves by cutting out the middle. But perhaps your right - if I started with a different case, I could solve the problem with the key movement.
dnny
PostPosted: Tue Jun 20, 2006 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
that is so right - there should be a warning on every DIY-page whit that text.
www.koelse.org
flickr: cable porn group
Audio files: 235
PostPosted: Tue Jun 20, 2006 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are a lot of nifty things you can do with an old junky piano.
Make a magnetic pickup by winding a bunch of varnished transformer wire around a small bar magnet. Hook this to a cable and plug it into an amplifier. Then take the speaker which is connected to the amplifier and put it really close to the open undamped strings. Now just bring that pickup near the strings and you'll have a neat feedback excited string "harp". If it doesn't start to sing, tap the pickup against a string to get it going. By moving the pickup to the different strings you'll play the different notes. You can even find the harmonic nodes on the strings. Great fun...
Oh, yes, you can always burn it. Sounds fabulous. If you do that, invite me... Wink
