 Forum index » Instruments and Equipment » Sequencers
alphabet soup for xp?
Page 1 of 1 [8 Posts]
BlueSquareSound
PostPosted: Sat Jun 24, 2006 6:04 am    Post subject: alphabet soup for xp?
Subject description: want to trigger sounds from keycaps
looking for qwerty based sampler for xp, something i could drag and drop samples to keycaps to trigger....
thanks
PostPosted: Sat Jun 24, 2006 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
A software sampler that you can trigger from the keyboard?
have you searched versiontracker.com?
PC?
In that case try to sniff around in this section:
http://www.versiontracker.com/windows/cat/audio
Flickr
Audio files: 235
PostPosted: Sun Jun 25, 2006 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm by far no expert in this stuff, but I've seen people using FL (Fruity Loops) trigger tracks from the QWERTY keyboards.
http://fruityloops.com/
klangumsetzer
Audio files: 37
PostPosted: Mon Jun 26, 2006 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
you could use hermann seib's vsthost ( http://www.hermannseib.com/english/vsthost.htm ) or tobybear's minihost ( http://www.tobybear.de/p_minihost.html ) in combination with a vst software sampler.
best regards
eike
edited to make links clickable - Seraph
PostPosted: Tue Jun 27, 2006 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Might be a slight case of over-bombing but Ableton Live will do that perfectly. Any sample can be asigned to any key for all sorts of trigger modes.
klangumsetzer
Audio files: 37
PostPosted: Tue Jun 27, 2006 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
kid beyond uses 'midi translator' to translate midi commands from a footpedal to issue predefined key commands and key combinations in ableton live.
best regards
eike
klangumsetzer
Audio files: 37
PostPosted: Wed Jul 05, 2006 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
hey,
maybe this will work?
http://www.axxeom.fsnet.co.uk/trollo.htm
best regards
eike
bigtex
PostPosted: Sat Jul 22, 2006 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're probably looking for something like BackToBasics.
http://www.wizardmaster.com/bludgeonsoft/btb/index.html
It's my favorite program from BludgeonSoft
...though they do make some fairly entertaining diversions. Like 0303 the PC motherboard piezo sequencer.
This software is made by the guy(s?) from Operation Re-Information
http://www.reinformation.com/
Fun stuff.
