Morse generator
Page 1 of 1 [3 Posts]
onosendai
G2 patch files: 4
PostPosted: Fri Aug 11, 2006 7:47 am    Post subject: Morse generator Reply with quote  Mark this post and the followings unread
From a Carbon idea on the mailing list, this is a sketch of a Morse generator. A neverend SOS message.
Use it only if you are in trouble Wink
(By the way it's my first patch, don't hurt me)
It works with the demo
Morse_generator.pch2
A sketch of a morse generator.
This version is a neverend SOS message.
 Filename:  Morse_generator.pch2
 Filesize:  2.12 KB
 Downloaded:  1896 Time(s)
PostPosted: Fri Aug 11, 2006 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is not meant to hurt you, your patch just got me thinking that it could be done in a different way which would make it easier maybe to make longer messages and that therefor you might be interested.
In the patchnotes (menu/patch/textpad) there is a bit of info about how it works.
I used http://en.wikipedia.org/wiki/Morse_code as a source of info.
Re. the messages on the NM list, this patch will not be directly useful for the NM classic (as it uses multiplexers) but the idea of using sequencers to control their own clock LFO would still be possible there.
This patch will work with the G2 demo as well.
morse.pch2
Another go at a morse generator
 Filename:  morse.pch2
 Filesize:  5.22 KB
 Downloaded:  3079 Time(s)
jima
PostPosted: Wed Sep 20, 2006 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I just LOVE variation 7, it sounds just like a transceiver I used to own
Sounds great on my G2 engine...
Jim
