<on air> Twyndyllyngs Chez Mosc
Access Virus Filter on NM
Page 1 of 1 [8 Posts]
CJ MMx
PostPosted: Wed Aug 30, 2006 12:08 pm    Post subject: Access Virus Filter on NM Reply with quote  Mark this post and the followings unread
Is it possible to recreate the character of the filter on NM?? i think that this task requires the connection of different filters using feedback lines.
Dark Psychedelic Emotions
Audio files: 235
PostPosted: Wed Aug 30, 2006 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe this topic will help. It's for the G2 but principles are what's important.
http://electro-music.com/forum/topic-6923.html
CJ MMx
PostPosted: Mon Sep 04, 2006 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
it's not exactly what I want. As i understood in that topic the guy created synth model which has almost the same filter routing as Virus has.
I want to know is it possible to get the sound of the filter.
G2 patch files: 626
PostPosted: Mon Sep 04, 2006 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
What does it sound like? All the Virus demos I have heard are swamped with FX. Don't they do a moog emulation on the C and up?
CJ MMx
PostPosted: Fri Sep 08, 2006 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I put an archive with virus C filtersweeps on pure SAW wave without any FX. Is it possible to recreate that sound on Nord Modular??
virus_sweeps.rar
 Filename:  virus_sweeps.rar
 Filesize:  2.36 MB
 Downloaded:  561 Time(s)
Audio files: 235
PostPosted: Fri Sep 08, 2006 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that's a lot of data.
Anyway, sounds like a pretty conventional 4 pole filter to me. Thanks for posting it. For all the hype, I was expecting something really unusual. I think the NM is quite capable of making these sounds. I guess it depends in what you are listening for though.
Maybe you should download the free G2 demo and listen to those filters. Then you could decide for yourself.
CJ MMx
PostPosted: Sun Sep 10, 2006 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I hope to see the answers of nord modular gurus, like Rob Hordijk, Roland kuit and others...
Kassen
PostPosted: Sun Sep 10, 2006 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Nah, the virus filter isn't unusual, it's just high quality. I think the main difference is in how the feedback path works, this mainly affects the usual suspects-; high resonance and high frequencies. The situation can be improved by taking the feedback loop out of the filter module itself and putting a extra interpolation function in it. This -however- runs into execution order trouble on the NM as well as a extra sample delay which means it'll be detuned, especially at higher frequencies.
The G2 filters share that bt of code so just taking a G2 doesn't fix it nor can the G2 do anything about the extra sample delay, the G2 does have more facilities for dealing with the execution order trouble.
Kassen
