workaround for self optimising modules?
Page 1 of 1 [10 Posts]
duracell
PostPosted: Tue Sep 28, 2004 11:49 am    Post subject: workaround for self optimising modules? Reply with quote  Mark this post and the followings unread
I'm used to the micromodular where yellow (logic) and blue (control) signals used very little dsp ressources in a patch, but with the G2 these modules all self update to audio b/w and use up a lot more dsp than before. in my case this means 'less' dsp power on a g2 patch than on a micro modular!
my patches worked just fine at a lower sample rate, so this seems like wasting cycles.
so my question: is there a way to downsample a red cable into a blue one, or make sure a yellow stays yellow and doesn't turn orange?
PostPosted: Tue Sep 28, 2004 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi duracel, welcome to the forum.
Yes you can downsample by using a note quantizer module, just leave it at its default settings. This will save an amazing amount of DSP resources sometimes !
Jan.
duracell
PostPosted: Wed Sep 29, 2004 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
YES!
true, the power saved is quite amazing.
does everybody else already know about this?
thank you jan
duracell
PostPosted: Wed Sep 29, 2004 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
just an example:
patchload figures
cycles 87.0 memory 67.2
after downsampling using note quantizer
cycles 42.2 memory 72.7
WOW!
PostPosted: Wed Sep 29, 2004 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, hard to know :-)
maybe we need a G2 FAQ !! Anyone ?
Jan.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Sep 29, 2004 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've used the notequantizer module on audio signals before for the downsampling effect, but it never quite clicked that this would also save dsp (even though the blue cables were staring me in the face Smile). Thanks Jan!
sebber
G2 patch files: 33
PostPosted: Mon Sep 11, 2006 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this still true? I tried it with the "Welcome G2" patch and nothing happened.
Fish don't swim. They dive.
sheridan
Audio files: 27
PostPosted: Mon Sep 11, 2006 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have used this method in a performance before... it was very strange at times! When sending control signals over a bus, sometimes I found that I had to scale the quantiser module to half, third, etc. depending on the voice count! At other times, the pitch would sound wrong and I'd have to put the value back to full! I was going to post at the time, but couldn't repeat the problem in a simpler patch, so I didn't bother. This post just reminded me.
transformer Sheridan
sebber
G2 patch files: 33
PostPosted: Wed Sep 13, 2006 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm. I just wonder if there's a generale rule. Can anybody name a patch where inserting the quantizer works wonder? Like diminishing the patch load by 50% as described above?
sheridan
Audio files: 27
PostPosted: Wed Sep 13, 2006 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I needed four to get this patch to work... I had no chance without them!
http://electro-music.com/forum/topic-7614.html Very Happy
