today> Various Artists September equinox Concert
Four-quadrant mult
Page 1 of 1 [18 Posts]
Freq Band
PostPosted: Thu Sep 14, 2006 9:34 pm    Post subject: Four-quadrant mult
Subject description: how deep does it go?
By "deep" I mean, it seems to wear many hats. The web reveals it could be a VCA, RingMod, oscillator, and help prove various chaos theories.....
http://www.urel.feec.vutbr.cz/ra2007/archive/ra2006/abstracts/005.pdf
Razz
I'm attempting this one:
"4ch Four -Quadrant Multiplier" by Jonatan Liljedahl
http://www.synthdiy.com/files/2005/kyma_multiplier.pdf
First off, might there be a reason he uses 2 tl072's ?
I'm going to try it with a quad opamp.
What do 'ya think the pots' values might be ?
Do you have any good ideas on what I could do with the other unused half of the MLT04 ? (I might put a duplicate circuit on the other half of the board.)
I happed to find 4 of these MLT04's (pulls).
Audio files: 226
PostPosted: Sat Sep 16, 2006 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think one quad op amp would work, that the pot might be 100K.
Check out http://www.musicfromouterspace.com/analogsynth/RingModulator/RingModulator.html
PostPosted: Sat Sep 16, 2006 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
The LM1496 is a neat chip to play with also. It can also be used to produce product terms. For example, inputting the same signal on both carrier and modulation will product a squaring circuit that produces double the frequency when using bipolar signals. The PAIA 9710 VCA/Mixer uses this IC. I have a few extras in my parts bin also.
http://web.mit.edu/6.301/www/LM1496.pdf#search=%22LM1496%22
Mosc, I like that AD633 chip also !! The Blacet "Klanc Werk" module uses this IC and I can get some CRAZY shit out of this thing when modulatiing from complex waveform sources! Very Happy
http://blacet.com/KW.html
Bill
Audio files: 226
PostPosted: Sat Sep 16, 2006 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 1496 is fine, but it needs trimpots. The AD633 is laser trimmed. For so little money, you might as well go hi-tech...
PostPosted: Sun Sep 17, 2006 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
You know, one can never argue with good logic .... Wink
Bill
bugbrand
PostPosted: Sun Sep 17, 2006 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
...&, as ever, AD633 is available as a free sample from www.analog.com - I've had plenty of them over the last 6 months and they're great for really simple but powerful ringmods yes yes yes!
http://www.bugbrand.co.uk
Audio files: 226
PostPosted: Sun Sep 17, 2006 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Back to the topic.
The AD633 has some great freaturs other than laser trim. It has builtin op amps on the two inputs, and one on the output.
Why not use these anytime you need a mixer? It's just as easy to use as an op amp, but it makes the mixer stage voltage controlled.
These multiplier ICs can be used as single chip VCAs and the can be used like a voltage controlled resistor in many applications.
Why not use them on any input? and for that matter, on every output? Then you have the potential to add voltage control to just about every point in the circuit. You can choose not to use that voltage control, but it's nice to have easy to wire it up.
It's a good building block to master - like the op amp.
Funky40
G2 patch files: 5
PostPosted: Sun Sep 17, 2006 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is very very interesting what you are telling mosc.
Really as easy as with op amps ?
What you say is maybe the solution for many things i was thinking about the last Days.
But i just learned to build a mixer on Breadboard this Days.
Dou you know (simple? )schematics where this things are done allready ?
edit: do i understand right: you suggest to use the AD633 instead of normal OP amps ?
Scott Stites
Audio files: 96
PostPosted: Sun Sep 17, 2006 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes - Mosc sprecht the truth I use mine as a voltage controlled attenuverter quite often, for example.
Cheerio,
Scott
Freq Band
PostPosted: Sun Sep 17, 2006 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can these chips be used as oscillators?
I've built the circuit, but have not yet powered it up. I need to build a +- 5v psu (for the MLT04......the AD633 is "up to" +- 15v I believe ??).
This may be off topic, but Mosc mentioned "...voltage controlled resistor..... ", and I remembered seeing datasheet apps using opamps configured as a FDNR (frequency dependant negative resistor). Is this of some use in a synth module ?
=FB=
Audio files: 226
PostPosted: Mon Sep 18, 2006 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I mentioned using the multiplier as a building block on inputs and outputs as food for thought. I don't do building myself anymore and I can't provide schematics. Maybe someone else can do that.
As for a voltage controlled resistor, the multipler itself won't do that too well I don't believe. A resistor has the E=IR response. So if you want to control a currant, then the OTA is a much better choice. What I was saying is that in many applications people use a Varactor as a sort of voltage controlled resistor to makie voltage controlled gain stages. While a little bit more expensive, the 633 would do that function, and much more accurately.
I'm sorry if my thinking out loud was confusing...
PostPosted: Mon Sep 18, 2006 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the last line in Mosc's post sums it all up. Master it and shove it in your toolbox for later use. Another useful tool. The more types of IC's you master, the better off you will be as a designer or DIY builder. The post is a good example of thinking outside the box (I know thats an overused term but it is approiate here to use). Example: Hey I have an IC that was intended to do THIS, BUT, I can use it to do THAT also ...
Audio files: 226
PostPosted: Mon Sep 18, 2006 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the op amp is pretty easy to understand for non-engineers. I think something like the 633 is too. The OTA is more difficult. Much for DIY synth design involved glue - finding useful and creative ways to hook up modules. OTAs are almost invaluable for building filters and oscillators, but the 633 could make designing glue a lot easier.
As DrJustice says, and now back to our regularly scheduled program... Very Happy
bugbrand
PostPosted: Mon Sep 18, 2006 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
...most interesting...
I wish I was more understanding with the engineering / electronics.
And, yes Freq Band, the AD633 datasheet does give an example of VC quadrature osc (along with some other things such as squaring and division that I really oughta try out on the g2)
PostPosted: Tue Sep 19, 2006 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
A good background in Mathematics does go a long way in electronics engineering but is not always mandatory. I use mathematical analysis quite often in my work but a resistive decade box or a stack of passives does go a long way when prototyping!.
The process of analog multiplication is actually achieved though the process of addition and the use of non-linear amplifiers. let me explain: First the math. If for instance you want to multiply variables X and Y, you can do the math using Log functions:
(The following examples cover only positive numbers for now so we are only talking single quadrant multiplication)
Given the equality: (Log X + Log Y) = (Log X*Y)
Thus, if you take the log of X and Y, add them, then take the antilog (the Log BASE raised to the result, this case will will use BASE 10) of the result, you get a multiplication of X and Y. So the formula becomes:
10^ (Log X + Log Y) = X*Y
For example 10^ (Log 6 + Log 2)=12
You might ask, why go through all of this just to multiply two numbers? Well before digital computers there were analog computers. If you use non-linear OP-AMP building blocks, its easy to construct LOG/ANTI LOG, and SUMMING AMPS to create multipliers to perform the above simple equation. Just 4 OP-AMPS and 3 Transistors will basically get you there at a bare minimum to construct a multiplier. Lucky we have IC's that do all of this analog magic but it's fun to use the language of mathematics to explain just how things are done ... Very Happy
bugbrand
PostPosted: Tue Sep 19, 2006 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hehe -- I've done a plenty of maths over the years up to degree stuff (yup, engineering based) - but, you know, it was never particularly tied in to anything really practical - always seemed abstract and kind of kills the creative buzzes. Maybe it was the way it was taught - I love the crossing of science and art but there wasn't much of that in the department (Son, you need to get yourself a proper job!) Never had more than a fraction of actual electronics taught to me - all been picked up by all the wonders of info about on the net and a few books..
PostPosted: Tue Sep 19, 2006 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, self learning is a unique discipline and a show of intelligence!! Good for you. Wink I have seen some of your creations and read your posts! I like what I see. Very Happy
OK, now back to the topic ... GRIN
Audio files: 226
PostPosted: Tue Sep 19, 2006 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I have a masters degree in electrical engineering and specialized in IC design. My advice is don't worry one bit about what goes on inside an IC, its very complicated and everything changes over time as the technology evolves anyway.
Just learn the simplified model for an ideal op amp (infinite input impedance, infinite gain, zero output impedence, zero input offset voltage) and use the multiplier and other chips as ideal black boxes.
