change grid (??)
Page 1 of 1 [11 Posts]
W.T.
G2 patch files: 11
PostPosted: Sun Sep 24, 2006 2:38 pm    Post subject:  change grid (??) Reply with quote  Mark this post and the followings unread
I was thinking about building a sequencer that is more than just 16 steps.
i came up with this idea to use a 16th grid to trigger a lfo that is clocked to the master clock (lfo B)
the clk rate is than controlled by a level sequencer and the length of the lfo output goes trough a envelope.
I think this is a nice solution for creating wild / exotic rhythmic sequences.
But i have a question: is this a good way or can this be achieved in a much more efficient way. (i think there must be Smile )
rtm.pch2
rtm patch
 Filename:  rtm.pch2
 Filesize:  1.98 KB
 Downloaded:  1726 Time(s)
Audio files: 316
PostPosted: Sun Sep 24, 2006 2:45 pm    Post subject: Re: change grid (??) Reply with quote  Mark this post and the followings unread
So do I Very Happy
W.T.
G2 patch files: 11
PostPosted: Sun Sep 24, 2006 4:09 pm    Post subject:   Reply with quote  Mark this post and the followings unread
thanks Jan Exclamation
any ways of doing this are welcome Cool
W.T.
G2 patch files: 11
PostPosted: Mon Sep 25, 2006 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
no one Question
cebec
G2 patch files: 31
PostPosted: Wed Sep 27, 2006 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
this is a cool idea!
W.T.
G2 patch files: 11
PostPosted: Mon Oct 09, 2006 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
k.e.p.
PostPosted: Thu Oct 19, 2006 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you seen Rob's "VariableStepLengthSequencer" for this kind of stuff!!
http://www.electro-music.com/forum/topic-11424.html
I really like it for making rhythms beyond the plain 16th-grid!
And I made me a little Max Patch for programming this one, because programming the level sequencer to the right note values is not very intuitive and inserting/changing values completely changes your rhythm. So in Max I can programm step-lengths saying "1/16","3/32", and I can Copy/Paste parts/segments of the pattern to move them around for inserting/adding/changing durations Cool
I can post the patch as soon as I find the time to clean it up and make it ready for the Max Runtime Rolling Eyes
best
Lars
a max patch for programming Rob's VariableStepLengthSequencer
 Filesize:  10.81 KB
 Viewed:  520 Time(s)
W.T.
G2 patch files: 11
PostPosted: Fri Oct 20, 2006 3:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Lars that would be great. But i can do without runtime i have a copy of max msp Very Happy
i am very curious
greet
Jeroen
PostPosted: Sun Oct 29, 2006 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a good idea for performances, using MAX/MSP or Pd (or any other) to break out more info from the G2. I had thought of doing something similar with a little hardware device...I wanted a basic pattern sequencer (ala 303, and the korg electribes) but didn't want to use keys and wanted more than 8 sequences visible. This might work as the go-between. Thanks for posting, and please, post the patch when you get the chance!
k.e.p.
PostPosted: Mon Oct 30, 2006 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the delay!!
The problem is, that i used the ice.pump external from dspaudio for the keyboard control of the patch. But as it's a commercial external and they have their own policy regarding the release of apps using their stuff I decided to make a dspaudio free version, which basically means "re-engineering" the pump object for my needs. (i need this for a couple of other projects, too...)
But I'm pretty much done with this...
Maybe tonight Rolling Eyes
best Lars
k.e.p.
PostPosted: Mon Oct 30, 2006 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, no guarantee, but it seems to work (using a not yet finished keystroke handler). not sure if it initializes proper, maybe one has to reassign the cc#'s ..? Let me know!
If you don't have Max you can grab the Runtime for free!!!
http://www.cycling74.com/downloads/maxmsp
VSL_Beta.zip
a first beta of my Max Patch for controlling Rob's Sequencer.
 Filename:  VSL_Beta.zip
 Filesize:  407.48 KB
 Downloaded:  568 Time(s)
