What is a "MKS 2 / B=2,5, 100nF"?
Page 1 of 1 [10 Posts]
Chrometuna
PostPosted: Sun Oct 01, 2006 3:23 pm    Post subject: What is a "MKS 2 / B=2,5, 100nF"?
Subject description: Inhaled to much solder fumes, what is this thing?
From Andrew Sharp's Strip-Board layout
The parts list includes these things:
C1 MKS 2 / B=2,5, 100nF
C4 MKS 2 / B=2,5, 20nF
C5 MKS 2 / B=2,5, 20nF
What IS an MKS 2 / B=2,5, ???
Brain is sometimes no can work.
bob c
PostPosted: Sun Oct 01, 2006 3:48 pm    Post subject: Re: What is a "MKS 2 / B=2,5, 100nF"?
bob c
these are polyester film capacitors from WIMA (brand name), tolerance 20%, grid spacing 2,5mm (0.1 inch)
Chrometuna
PostPosted: Sun Oct 01, 2006 6:45 pm    Post subject: Re: What is a "MKS 2 / B=2,5, 100nF"?
bob c
Thanks.
How critical is it that the caps match these criteria? Meaning, can any polyester cap of the same values work?
PostPosted: Sun Oct 01, 2006 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep, +/-20% tolerance aren't that good anyway!
PostPosted: Mon Oct 02, 2006 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,
Sorry about that. That part list I gave to Ray is not very helpful. It's the one spat out by the stripboard software I use. I should have just said that the designators are the same as Ray's Schem, but that was back when I was very Noob! Laughing (the B=2,5 is the lead spacing! Rolling Eyes )
Any 100nF polyester cap would do fine.
PostPosted: Mon Oct 02, 2006 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed that's what i meant though i didn't say it (unfortunately i'm not a native speaker)
Chrometuna
PostPosted: Mon Oct 02, 2006 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
So does it absolutly HAVE to be a polyester cap?
I still dont know what the real difference between ceramic, poly, or whatever cops are.
sneakthief
PostPosted: Mon Oct 02, 2006 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
You should read this capacitor tutorial:
http://www.uoguelph.ca/~antoon/gadgets/caps/caps.html\
michel
Sneak-Thief - raw electrofunk
PostPosted: Mon Oct 02, 2006 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, it doesn't. a regular ceramic cap will do... (as ray mentions caramic caps for all non polarized caps in his bill of materials).
PostPosted: Mon Oct 02, 2006 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah ceramic is fine.
The only reason I forgot to mention them is 'cos I forgot they go up that high.
Unless temp stability or tolerance is critical;
most cap types are chosen for the values possible for that type, the voltage rating, their size, and cost. Generally, if it has the right value, is polarised or not, and fits where you want to put it, it will be fine.
