 Forum index » Instruments and Equipment » OSX as a music workstation
Any way to assign the buttons to note on and note off?
Page 1 of 1 [7 Posts]
arne
PostPosted: Sun Nov 12, 2006 12:16 pm    Post subject: Any way to assign the buttons to note on and note off? Reply with quote  Mark this post and the followings unread
hmm anyone?
I want to control the program LiSa from steim.nl with my G2.
I need to be able to control note on and off to trigger zones with the buttons.
Thank you
arne
PostPosted: Sun Nov 12, 2006 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome arne.
How about using a NoteSend module with a switch (SwOnOff) conected to the gate input (there is no need to connect anything to the switch input). Set the Note value to the note that must be turned on/off.
arne
PostPosted: Sun Nov 12, 2006 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
The switch works, both the Momentary and Toggle module!
But how do I assign the on/off button to the Button, without the knob that is, on the G2?
Thank you.
arne
I will post the final result up here when I have made the patch.
arne
PostPosted: Mon Nov 13, 2006 3:52 pm    Post subject: Here is the LiSaX Midicontroller patch. Reply with quote  Mark this post and the followings unread
Hello
Here is the LiSaX midicontroller patch v1.0
arne
G2_LiSaX_V.1.0.pch2
 Filename:  G2_LiSaX_V.1.0.pch2
 Filesize:  8.91 KB
 Downloaded:  1283 Time(s)
arne
PostPosted: Tue Nov 14, 2006 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
New zip with the LiSaX Setup that I use with the patch, without my samples and Patterns.
arne
G2_LiSaX_V.1.0.zip
Zip with the LiSaX Setup and the same patch as above.
 Filename:  G2_LiSaX_V.1.0.zip
 Filesize:  16.27 KB
 Downloaded:  470 Time(s)
PostPosted: Tue Nov 14, 2006 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Was tempted to move this to the Clavia forum, if it were not for Lisa Very Happy
Also see : http://electro-music.com/forum/post-95997.html
arne
PostPosted: Tue Nov 14, 2006 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Thanks.
You could move it to the Exernal controller listing i guess..
arne
