Is it possible to separate the Button and The Knob?
Page 1 of 1 [5 Posts]
arne
PostPosted: Mon Nov 13, 2006 9:21 am    Post subject: Is it possible to separate the Button and The Knob? Reply with quote  Mark this post and the followings unread
Hello
I am making a patch to control LiSa from steim.nl with the G2.
To trigger zones in LiSa you need to send a note on.
I manage to do this with a switch and a note on Module.
But.. I want to separate the Knob so that it can be a controller for other
things.
Is it possible to separate the Button and The Knob or do I have to use another module?
Thank you!
ab
PostPosted: Mon Nov 13, 2006 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Try using a sequencer module, then assign midi to the value, as well as the trigger. This will give you access to both the knob and the button discretely.
arne
PostPosted: Mon Nov 13, 2006 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes! it works... I´m patching Smile
PostPosted: Mon Nov 13, 2006 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's unfortunate that there is no knob/button module (it's been asked already in the wishlist area). But, as long as you are happy with the work-around, that's what matters.
Audio files: 297
PostPosted: Tue Nov 14, 2006 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let me link things a bit : http://electro-music.com/forum/post-95921.html
