SL not working....
Page 1 of 1 [6 Posts]
rubendelacosta
PostPosted: Sun Nov 26, 2006 7:44 pm    Post subject: SL not working.... Reply with quote  Mark this post and the followings unread
damn it....it's not working.
switches are making this strange "clop" noises every time i turn them on...
for a moment there was something like a pulse in a regular beat so i tried the VCF and it was working ok. But sudly the pulse stoped.
plus there was this static noise, similar to a hanging jack....
any sugestion?
oh....i made my self the pcb board...but i think that thers no misstakes on it.
thanks, ruben.
PostPosted: Mon Nov 27, 2006 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd start by trying some new batteries.
rubendelacosta
PostPosted: Mon Nov 27, 2006 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
there are some progress!
White noise is working.
AR is working
Lfo i guess it's not workig as it should
and the filter is perfect.
the Vco's are kind of strange...the frequency pot it's controling the white noise, but they are not making any sound at all.
and there's still some "clop" noises whene i turn on the switches....but i guess it's just some ground problems.
any ideia?
PostPosted: Tue Nov 28, 2006 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If the frquency pots are controlling the noise then it's definately a wiring fault. Re-check all the panel to PCB connections. I'd say most of the mistakes on a SoundLab would be these connections. I had a mistake on mine which I didn't even realise for a couple of months! Laughing
PostPosted: Tue Nov 28, 2006 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, for me it sounds like a wiring related issue.
did you triple check the wiring after all that rewiring of the switches?
the next step would be to check the signals at the significant points: consult rays article about troubleshooting circuits and the troubleshooting guide for the SL if you not already did...
good luck...
rubendelacosta
PostPosted: Tue Nov 28, 2006 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
i made an hard decision....but it's for the best...i'm going to re-wire everything Sad . The all wiring it's a mess i can't re-check anything. I'm going to try to do a nite job.
thanks for all the help, rubens.
