wsg - 2nd circuit
Page 1 of 1 [4 Posts]
ultra
PostPosted: Mon Dec 04, 2006 9:48 am    Post subject: wsg - 2nd circuit
Subject description: wsg - 2nd circuit
hello! i'm new to this forum and this is my first post. i've ordered parts for the sound lab mini-synth so i guess i'll be around quite a bit Smile.
i'm building the small wsg random noise synth and i have a question about wiring in the second circuit, according to the original schematic found here:
http://www.musicfromouterspace.com/analogsynth/YOUR_FIRST_SYNTH/your_first_synth.gif
between R2 and C9 you can wire in the second circuit, which is a replica of the first circuit. the only thing i don't understand is what part of the second circuit is wired into that point. is it the part that is equivalent where u1's pin 2 connects to r9?
thanks for the help!
Joel
PostPosted: Mon Dec 04, 2006 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi and welcome!
A bit of hunting around (I knew I'd seen this pic somewhere) brought up this thread, the picture in one of the responses should clear things up for you!
There's 2 attachment points for the 2nd circuit, depending on whether you want a pre-filter ouput or not (not really necessary I don't think...)
Good luck Very Happy
Joel
Audio files: 235
PostPosted: Mon Dec 04, 2006 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Ultra
ultra
PostPosted: Mon Dec 04, 2006 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
