nord_balls
Joined: Nov 07, 2005 Posts: 15 Location: New York, NY
Posted: Thu Dec 07, 2006 10:53 pm Post subject:
Keyboard Hold woes Subject description: how to make a multi-slot keyboard hold control |
Hi y'all,
Been futzing with this for a while and read some posts and am stuck.
Keyboard hold (CC# 18) seems to be a very finicky control. See attached patch, where I've rather clumsily put together a toggle switch that sends either 0 or 127 out on CC 18.
Well, no matter how I set the CtrlSend module's send channel -- this, the current midi channel, the slot, other slots, other channels -- keyboard hold will not respond.
I've tried it on other CC#s, like volume, octave -- they all work like a charm.
Now here's the tripper: if I have my keyboard hooked up in and out to my computer with a midi recorder, record-enabled, so it's echoing back -- it works (on the channel that the midi recorder is echoing back on).
The reason I'm creating this is I want a master keyboard hold that I can point at other slots. I've already given up on trying to somehow "capture" the keyboard hold button itself, so I was trying this way using a switch. Nothing worky. Helpy?
Thanks,
Stuart
| Example of attempt to create a keyboard-hold control: works over midi echo, not within nord |
 Download (listen) |
| Filename: |
keybhold.pch2 |
1.07 KB |
| Downloaded: |
1366 Time(s) |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Fri Dec 08, 2006 12:57 am Post subject:
| I used CC64 for hold which works but has a problem. If you load a new patch while the CC is high, that slot gets stuck on hold till a power reset or CC64,0 is sent. |
nord_balls
Posted: Sun Dec 10, 2006 3:25 pm Post subject:
sustain != hold |
| g2ian wrote: | | I used CC64 for hold which works but has a problem. If you load a new patch while the CC is high, that slot gets stuck on hold till a power reset or CC64,0 is sent. |
That is the same as holding the sustain pedal, no?
My love for keyboard hold comes from the fact that held notes reset at the next non-connected note; sustain would just hold everything until I reset the sustain setting.
I wonder what Clavia's thinking was behind this implementation of keyboard hold. It's a strange function to begin with and very hard to duplicate via programming, whereas I've been able to get poly/mono switching, sustain (release modulation) and other things by hacking away with the editor. Maybe I'll give it another shot ... |
