time quantizing?
Page 1 of 1 [11 Posts]
astroid power-up!
PostPosted: Thu Dec 14, 2006 5:13 pm    Post subject: time quantizing? Reply with quote  Mark this post and the followings unread
the pitch quantize functions are wonderful and facile.
has anyone built a time quantizer?
because if i had a pitch and time quantizer, i could just bash on the keys and sound great!
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
Audio files: 309
PostPosted: Thu Dec 14, 2006 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like this or needs it be more complicated ?
time-quant.pch2
 Filename:  time-quant.pch2
 Filesize:  1.42 KB
 Downloaded:  2882 Time(s)
deknow
PostPosted: Thu Dec 14, 2006 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
....i think howard was working on something like this.
deknow
Audio files: 235
PostPosted: Fri Dec 15, 2006 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
You might be interested in this topic.
http://electro-music.com/forum/post-22419.html
astroid power-up!
PostPosted: Fri Dec 15, 2006 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's a cool idea which i will surely find an application for, but i'm thinking more along the lines of something that might store and quantize a certain number of notes, not just gate the ones it likes.
like, just from a rythym sense, if i played
jh jkhkdjfh kjlasdf
it might spit out
j h j k h k d j f h (and then probably lose some data, because we'd be working with the logic modules)
sheridan
Audio files: 27
PostPosted: Sat Dec 16, 2006 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe something like this?
time quantiser.pch2
Time quantiser
 Filename:  time quantiser.pch2
 Filesize:  1.08 KB
 Downloaded:  1648 Time(s)
transformer Sheridan
Hear music and Nord Modular G2 patches and find out music production tips at
http://www.nitetimeproductions.co.uk
astroid power-up!
PostPosted: Sat Dec 16, 2006 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
closer, yeah.
i'm gonna try to expand on that.
astroid power-up!
PostPosted: Sun Dec 17, 2006 2:47 am    Post subject: Reply with quote  Mark this post and the followings unread
well here's something expanding on sheridan's idea for using a s&h.
it's not flawless, but kind of a neat effect. open up the patch and just pound away on the keys.
what i really don't understand is what's happening when you turn up the polyphony to eight or so. does it mean that the patch is remembering eight values for each s&h? if so, RAD.
big wtf.prf2
 Filename:  big wtf.prf2
 Filesize:  3.74 KB
 Downloaded:  1742 Time(s)
astroid power-up!
PostPosted: Sun Dec 17, 2006 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
ways that i'd like to improve this (and maybe someone could help):
the overall effect is good, that you can play arpeggios, and it kind of mauls them, but keeps everything in time with the clock. that's working for me.
but what isn't working for me is the bit of triggering sloppiness. maybe it's a monophonic issue, but the notes seem like they're changing value independently of the timing. it might have to do with the amp decay relative to the clock...
also, it's not really elegant
astroid power-up!
PostPosted: Sun Dec 17, 2006 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
ahaha
so what i figured out that it's doing is this:
it stores your most current keystroke 8 in advance (per voice, so if you have the polyphony at 8 voices, it's doing this 64 values in advance) and then it plays the store values in order as you're hitting the keys-but it plays those in time with the clock. almost what i want.
astroid power-up!
PostPosted: Sun Dec 17, 2006 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
well, now it seems like the "shift register" delay module is the way to go. always wondered about that one. i'm confused why that isn't considered a logic module, or more appropriately, a "note" module. i guess because it's using the memory....
anyway.
so, looks like what i actually want to do is to create a kind of buffer, one which holds the last recieved values and then flushes them in time with the clock, and then stops triggering notes when there's no more notes in the buffer.
but now i gotta sleep.
