Joined: Apr 03, 2004 Posts: 24666 Location: The Netherlands, Enschede
Posted: Sat Dec 16, 2006 5:28 am Post subject:
Ah there it is, good job Bill & Tom ! _________________ Jan
Posted: Sat Dec 16, 2006 5:42 am Post subject:
I've tried downloading that .pdf a number of times now, but it always comes up with an error in Adobe which says, "the file was damaged and could not be repaired" _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sat Dec 16, 2006 5:59 am Post subject:
Hmm, strange ... I did not have a problem with the PDF (i'm still using version 7). _________________ Jan
Posted: Sat Dec 16, 2006 6:20 am Post subject:
Maybe it's because I'm still using 5?  _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sat Dec 16, 2006 6:49 am Post subject:
Probably, I saw Bill mention 6 somewhere I think  _________________ Jan
Posted: Sat Dec 16, 2006 8:27 am Post subject:
| Quote: | | Probably, I saw Bill mention 6 somewhere I think |
Yup, you are correct! Just grab the free Adobe reader 8.0 ...
This document will work with >= 6.0 .......
http://www.adobe.com/uk/products/reader/
Bill |
richardc64
Audio files: 26
Posted: Sat Dec 16, 2006 1:41 pm Post subject:
I must admit that I really dislike Acrobat too. I don't have it installed here- I much prefer Preview. _________________ ACHTUNG!
Posted: Sat Dec 16, 2006 3:07 pm Post subject:
Just to let you all know, Tom and I are working on getting a better looking document up on this thread so hold tight, for now, the current PDF will have to suffice. I will look at things tonight ....
After that, we can get things rolling and have some of you build these Hi-Hat synthesizers.
As promised also, I will try to get some samples of the Clangora up from my hard drive ... I know I have a few things !!
Bill |
Posted: Sat Dec 16, 2006 4:59 pm Post subject:
Nup,
I've installed Reader 8, and I still can't get it. Always comes up with the same error. Whether I try to open the link or save as. It's supposed to be 3.8MB and the download which is saved is only 329KB. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sat Dec 16, 2006 5:02 pm Post subject:
Hold your horses Unkle K
I think we are going to have to display these pages differently. It's going to take a little while. Can you hang on (to the walls? ) for a bit longer??
Tom  _________________ ACHTUNG!
Posted: Sat Dec 16, 2006 5:10 pm Post subject:
No stress,
I just get curious when something doesn't do what you think it should. It's possibly a fault with my PC anyway. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sat Dec 16, 2006 6:38 pm Post subject:
| Uncle Krunkus wrote: | | It's possibly a fault with my PC anyway. |
Time to get a Mac then??
(you have to admit that you fell for that one?? ) _________________ ACHTUNG!
Posted: Sat Dec 16, 2006 7:01 pm Post subject:
| v-un-v wrote: | | Time to get a Mac then ?? |
Nah, I'll wait for Lisa jr.  _________________ Jan
Posted: Sun Dec 17, 2006 2:07 am Post subject:
| v-un-v wrote: | Time to get a Mac then?? |
I said "fault", a fault can be tracked down and fixed.
As compared to an "as yet undocumented feature which will cost you an extra $1500 to enable"  _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sun Dec 17, 2006 3:22 am Post subject:
"undocumented feature"?
My Mac turns on, it works, Period.
The only $1500 you'll be spending is on another motherboard for your peepee- whoops peecee  _________________ ACHTUNG!
Posted: Sun Dec 17, 2006 3:27 am Post subject:
richardc64
Audio files: 26
Posted: Sun Dec 17, 2006 3:34 am Post subject:
While you're wearing down your fingernails hanging onto the walls, Uncle, here are gifs to keep you salivating.
http://www.geocities.com/richardc64/clang/
block = block diagram
figure2 = triggers and envelopes
figure3 = clatter (noise)
figure4 = clank
figure5 = VCAs and output
I find figures 3 and 5 most interesting. "Clatter" is pitched noise generated by modulating a VCO with noise. Figure5 uses the NE570 as VCAs. New ideas to play with. Thank you v-un-v |
Posted: Sun Dec 17, 2006 4:05 am Post subject:
I know what part of the problem is here now
Everyone keeps uploading these images as scans, but no one is converting them to black and white, resizing or adjusting contrast and brightness etc etc. The result is a less than acceptable image.
Come on you chaps!! I know that you are only engineers, but engineers should be able to get it right!!!!
Thanks for the uploads Richard, but we really need something a little clearer. I think this is important. _________________ ACHTUNG!
richardc64
Audio files: 26
Posted: Sun Dec 17, 2006 4:16 am Post subject:
| v-un-v wrote: | Everyone keeps uploading these images as scans, but no one is converting them to black and white, resizing or adjusting contrast and brightness etc etc. The result is a less than acceptable image.
Thanks for the uploads Richard, but we really need something a little clearer. I think this is important. |
I know. Just wanted to enable Uncle K to see something while he tries to correct his pdf difficulties.
I tried to clear up the images, but going b/w made them less readable. The current pdf is still usable, if one is sufficiently motivated;-) |
Posted: Mon Dec 18, 2006 6:30 pm Post subject:
OK fellas, I just sent our Moderator, v-un-v, a set of very acceptable images via e-mail. I am sure he will re-touch as needed and then post them to this thread to get things rolling. Again, hang tight for the "new and improved" version of the Thomas henry "Clangora" Nuts and Volts article. It's worth the wait as it is a VERY well written article and a fun project to build to boot!!!
Thanks,
Bill |
Posted: Mon Dec 18, 2006 6:35 pm Post subject:
| Quote: | | My Mac turns on, it works, Period. |
How about the new Macbook! I have been kicking around the idea of maybe purchasing one of those types. BTW .. gee, my PC turns on and works every time also ... I must have set it up correctly ...
Bill |
Posted: Tue Dec 19, 2006 4:11 am Post subject:
| State Machine wrote: |
How about the new Macbook! |
I think it's what you are used to
Me and Unkle K are always winding each other up- it's all part of the fun of being on E-M.com!!
But the next time I hear that line about Apple ripping off Xerox's OS.... I'LL SCREAM!!!!  _________________ ACHTUNG!
Posted: Tue Dec 19, 2006 8:03 am Post subject:
| Quote: | think it's what you are used to
But the next time I hear that line about Apple ripping off Xerox's OS.... I'LL SCREAM!!!! |
Politics, Religion, Computers, analog vs. digital, ... deadly and highly opinionated subjects ... and, what the hell is a "warm" sound anyways?
Yea, I hear you the OS thing, the PARC guys were a great think tank BUT Apple just saw something that worked and built on it ... Seriously, I am really thinking about wanting to run stuff on a MacBook.
I don't want to get too OT ....
Bill Last edited by State Machine on Tue Dec 19, 2006 8:14 am; edited 1 time in total |
