patch reset
Page 1 of 1 [6 Posts]
Bensen Raccoon
G2 patch files: 8
PostPosted: Fri Mar 24, 2006 5:12 pm    Post subject: patch reset Reply with quote  Mark this post and the followings unread
my appologies if i overlooked a simple solution to my problem.
i was wondering if there was anyway to assign a button or keypress to reset the patch? (ie. what happens when you attach a cable or add a module)
thanks
It is the jigsaw, it is purple haze, it never stays in one place, it is not a passing phase.
PostPosted: Fri Mar 24, 2006 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not in the editor, on the synth itself (not the engine of course) there seems to be a key combination. We had a topic about this a not too long ago, but can't find it right away - something with shift ???
PostPosted: Fri Mar 24, 2006 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just found a quick way for in the editor. Click on the perf knob in the tool bar, and then again. This togglees between patch and perf mode and back again, and it recompiles the patches.
Bensen Raccoon
G2 patch files: 8
PostPosted: Fri Mar 24, 2006 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the quick reply Blue Hell
i am actually looking for a way to recompile the patch from the keyboard... i will run search on the forum and check the manual...
thanks again for your help
Wan
G2 patch files: 46
PostPosted: Sat Mar 25, 2006 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure this is what you want, but Shift+var button resets that variation to its initial state (the state when first loaded). It doesn't undo any real patching though, that's only possible from the editor.
Grtz Wan
Bensen Raccoon
G2 patch files: 8
PostPosted: Sat Mar 25, 2006 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes sir, that is exactly what i wanted... thanks for your help
