yarmark
Posted: Tue May 23, 2006 9:38 am Post subject:
Can Modular be used as computer's sound card? |
I am *seriously* considering picking up a modular G2... Is this a feature of the hardware?
Any suggestions of similar products that can use their sound routing as the in/out for computer recording and bussing? I know that Access does this with their virus machines. any others?
thanks |
Alexander
G2 patch files: 4
Posted: Tue May 23, 2006 10:27 am Post subject:
I don't have any answer to your question, but why would you want to use a synth as a soundcard? |
yarmark
Posted: Tue May 23, 2006 10:42 am Post subject:
because i would imagine that the AD/DAs are good quality and it would therefore eliminate the need for an electronic musician such as myself to buy a separate sound card if I didn't require preamps or XLR plugs. It would also be very handy for recording/working on the road. |
Posted: Tue May 23, 2006 10:50 am Post subject:
No, won't work. I don't think it could either because it's USB1.0 and I don't think that can strech to 4*96KHz*24 bits, most certainly not full duplex.
It wouldn't make any sense either because far superior DA converters can be bought for far less and you'd end up summing your computer and synth before your mixer which would take headroom.
Access made a good sounding synth (I can't think of any digital hardware that sounds as good, eccepting some 70's stuff) but none of what they did after that made any sense to me at all. _________________ Kassen |
Posted: Tue May 23, 2006 10:52 am Post subject:
yarmark wrote: | because i would imagine that the AD/DAs are good quality |
No. THe G2 has the worst DACs I ever heard. Worse then a soundblaster 16, even worse then those atrociously sharp sounding things found in Apple laptops that make everybody sound like IDM. _________________ Kassen |
The USB connection is just for the software control of the G2 and not for audio and midi. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
yarmark
Posted: Tue May 23, 2006 10:59 am Post subject:
thanks for the opinions and infos both of you. the world never turns out to be as perfect as I want it to be. |
Posted: Tue May 23, 2006 11:02 am Post subject:
I wouldn´t say the DACs are the worst ever but there is a certain character to the sound that might be OK for an instrument but not for a modern DAW. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Tue May 23, 2006 11:38 am Post subject:
Well, ok, enough about the DAC'S.
I still think it's a bad idea even if we'd be talking imaginary perfect DAC's because except for the situation where the PC and the G2 would be your only gear and digital summing would be desired or acceptable it would create a gain-structure nightmare.
Good soundcards need not break the bank anymore. Some of the EMU pci cards are quite reasonable in price and and the "m" versions sound marvelous. _________________ Kassen |
Posted: Tue May 23, 2006 11:41 am Post subject:
By the way; some modern soundcards that come build in to motherboards feature a optical output but bad build in DAC'S; on a tight budget you could experiment with using the optical output directly to a modern HIFI amp. _________________ Kassen |
yarmark
Posted: Tue May 23, 2006 12:01 pm Post subject:
Kassen wrote: |
Good soundcards need not break the bank anymore. Some of the EMU pci cards are quite reasonable in price and and the "m" versions sound marvelous. |
Kassen, have you experimented with the EMU 1616 cardbus interface? |
slave to this
G2 patch files: 7
Posted: Tue May 23, 2006 12:34 pm Post subject:
Kassen wrote: | even worse then those atrociously sharp sounding things found in Apple laptops that make everybody sound like IDM. |
haha, i'm so glad someone else notices this. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue May 23, 2006 12:35 pm Post subject:
Re: Can Modular be used as computer's sound card? |
yarmark wrote: | I know that Access does this with their virus machines. |
I think it would be more correct to say that Access 'tries' to do this with the Virus TI. |
Posted: Tue May 23, 2006 12:37 pm Post subject:
yarmark wrote: |
Yes, I'm exceptionally pleased with the 1616m, I use one on my laptop. Do get the "m" because the plain 1616 uses the same DAC's as the G2. _________________ Kassen |
Posted: Tue May 23, 2006 12:42 pm Post subject:
slave to this wrote: |
He he he, you should hear Rob about those things...
I mean; they are ok for system sounds when sitting on the cough or whatever but this idea that Mac cards are so good that you can plug one directly into a PA is a bit silly. I do think they suffer less from data from the mouse/hd/lcd leaking into the sound then many PC build in cards but that's hardly saying anything. _________________ Kassen |
Joined: Apr 03, 2004 Posts: 24488 Location: The Netherlands, Enschede
Posted: Tue May 23, 2006 12:43 pm Post subject:
Kassen wrote: | because the plain 1616 uses the same DAC's as the G2. |
Same sound as the G2 ?
(just curous if maybe the same DACs in a different design could sound diferent). _________________ Jan
cebec
G2 patch files: 31
Posted: Tue May 23, 2006 1:53 pm Post subject:
Blue Hell wrote: | Kassen wrote: | because the plain 1616 uses the same DAC's as the G2. |
(just curous if maybe the same DACs in a different design could sound diferent). |
My opnion is that, yes, same DACs with different implementations will sound different. |
slave to this
G2 patch files: 7
Posted: Tue May 23, 2006 2:38 pm Post subject:
what are opinions, if any, about RME dac's? i want a fireface bad despite the price.
James |
Posted: Tue May 23, 2006 2:50 pm Post subject:
Ithink RME makes top quality stuff in general. I never heard anything but praise about them.
As for the G2/1616 thing; I'm not sure because I never heard a 1616 in action. I did look up the spec-sheets and those DAC's have a filter that can configured through software so yes; different implementations could very well sound radically different.
Also; I kinda regretted making fun of the sb16 because the sb16 even if it's cheap will always perform. I think every system under the sun has drivers for it so that's worth something too... _________________ Kassen |
Posted: Tue May 23, 2006 5:09 pm Post subject:
In general, the RME gear is quite good. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Tue May 23, 2006 5:32 pm Post subject:
yarmark wrote: |
I also have a 1616m cardbus, works like a charm. Very good sound, and even has a good handling of high signal levels, for those situations when someone else has a signal to add to the mix But those "m" grade ADC's are just wonderful. The patchmix does a lot of cool things, but only goes 1/2 way to what it really should be (like allowing the use of control surfaces, etc).
Anyway, it's worth the price. I've never heard anyone complain about the sound of RME, only the price. And they support any major OS, so that's always a good thing as well. |
Posted: Tue May 23, 2006 6:31 pm Post subject:
slave to this wrote: | what are opinions, if any, about RME dac's? i want a fireface bad despite the price.
James |
It all depends on features and what you what to use it for. In general the RME gear is excellent. Depending on what you are actually going to use it for, you might like to look into stuff like the Echo Audiofire series and the latest Apogee stuff too. A lot of the MOTU gear is quite good too.
Trivia: At the moment I am working my way though some recordings of orchestral percussion done with the Echo Audiofire 12. These are really sweet. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Sun May 28, 2006 3:53 pm Post subject:
yes this would be awesome and puts the G2 in the back seat in comparison to say the T1 etc however the G2 makes up for this in its sound which is quite nice. But yes each new product is like a swiss army knife now days doing everything the G2 is not entirely like that but boasts other powerful features such as its 4 individual inputs allowing extensive processing I hope this is of some help. Oh yes I have a fireface and LOVE it I love RME anyway... used to do tech support for em too. But again there are so many new products coming out its staggering. Aside from converter quality look towards low latency Drivers indeed. |
