the most idiot question ever
Page 1 of 1 [6 Posts]
rubendelacosta
PostPosted: Sun Nov 26, 2006 8:56 am    Post subject: the most idiot question ever
Subject description: please help
hi there!
in a spdt switch with the center OFF witch leg is "1" "2" and "3"?
thank you, ruben.
PostPosted: Sun Nov 26, 2006 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
pin "2" is the one in the middle, pins "1" and "3" are the two "ONs".
mounting the switch be aware, that if you put the nipple down the connection is made to the upper pin and if you switch up the connection is made to the lower pin...
cheers,drunken
rubendelacosta
PostPosted: Sun Nov 26, 2006 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
ufff
for a moment i thought that i would have to re-wire all spdt switchs.
thank you for your time, ruben.
PostPosted: Sun Nov 26, 2006 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
oops, wasn't aware that this question was SL related. ray doesn't seem to follow the conventions seen in other schematic drawing software. he obviously designates the leg in the middle as "1" (which seems to make sense in a way).
i never took a look that close on the schematics, i just wired my SL according to the wiring diagrams! sorry for that confusion.
cheers,drunken
rubendelacosta
PostPosted: Sun Nov 26, 2006 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i allready re-wired the switchs. I wasn't such a hard job. Very Happy
thank you again rubens.
PostPosted: Sun Nov 26, 2006 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you take a look at various datasheets for SPDT switches you will see, that the legs are numbered from "1" to "3" with "2" being the middle one. that's the reason for my first anwer. looking at ray's schematics i have to say that he numbers the leg in the middle as "1" instead! confusion, heh? anyway, take a look at a datasheet for a SPDTs. it will show you how it's mechanics work and a look at the wiring diagrams says it all...
good luck and sorry for that inconvenience again. don't forget to let us know how you get along with yout SL
cheers,drunken
