A DIY "no-MIDI" guitar controller for 1V/Octave synths
Page 2 of 3 [68 Posts]
Macaba
PostPosted: Tue Feb 27, 2007 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
For anti-aliasing purposes, yes. You want a low pass filter that rolls off at half the sampling frequency. In the real world, you would roll off earlier, to ensure the high frequencies are attenuated sufficently.
Good observation! Smile
stefano
PostPosted: Tue Feb 27, 2007 2:06 am    Post subject: Re: First success
Subject description: .. but a lot of work is still needed ..
stefano wrote:
stefano wrote:
PRODUCTION OF SAMPLES AND PHOTOS IN PROGRESS.... Cool
Yes, sir, yesterday the Penfold F2V Guitar to Synth Interface started to convert guitar frequencies to voltage. I say "SOMEHOW" because I had to make a little mod (or bypass) to start it work. And I think that the device is not working in the way that Penfold designed it... but it WORKS.
I suspected that the signal path "stopped" at the gates of the quad switch 4016BE (I use a MC14016BCP for IC4). IC4 is driven at pin 13 (control pin) by a signal coming from pin 4 of IC11b, so I wondered what would have happened if pin 1 and pin 2 of IC4 would have always connected (like if the control al pin 13 was always enabled). The easiest way to do this is to **short** pin 1 and pin 2 of IC4. I did it and immediately the circuit started to convert frequencies to voltages.
The mini sound lab accepted the 1V/Octave scale produced by Penfold P2V.
I played an A (5th guitar string), tuned the osc-1 Minisoundlab and VR2 (shift control). Then I played the same string at the 12th fret (1octave up) and I used the VR3 (gain control) to tune the sound from the oscillator.
I didn't win the war, but I think at least a good battle! I'm on my way to completely debug this circuit because I don't actually like this bypass Twisted Evil .
Next step I'd like to do with an oscilloscope (any advice accepted Very Happy ):
- controlling the signal at (IC11 pin 4) = (IC4 pin 13) (after generation of quad switch control signal)
- controlling the signal at IC10 pin 6 (before generation of quad switch control signal)
Stay tuned
Here is a photo of the loaded PCB.
At the moment I'm trying to discover if the quadswitch MC14016BCP is damaged.
Another issue could be the power supply. I discovered that I have a positive supply of exactly +12 V and a negative supply of - 10.5 V . Do you think this could be a problem for the biasing of the components ?
Bye
Loaded Penfold's Guitar to Synth PCB
 Filesize:  299.25 KB
 Viewed:  507 Time(s)
bugbrand
PostPosted: Tue Feb 27, 2007 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I reckon I'm going to make one up shortly too --- Stefano, that's the PCB straight from the project document, right?
All the parts look pretty standard which is good -- reckon I'd use an SSM2210 instead of CA3046 though..
http://www.bugbrand.co.uk
PostPosted: Tue Feb 27, 2007 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
what about the MS20 interface? (just a guess)
Indeed Very Happy
The P-V converter on the MS-20 is what makes this synth so good. I've got the schematic if you need it. (although it isn't hard to find on the net). You can drive both the Soundlab and the SN7 voice from Hz/oct. So no more searching for tempco's? Wink
ACHTUNG!
stefano
PostPosted: Tue Feb 27, 2007 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Indeed Very Happy
Why not. Let's have a look at the schematic. Can you post it (otherwise, can you post the link?)
bugbrand
PostPosted: Wed Feb 28, 2007 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Duh, silly-bugs -- of course I then realised that the CA3046 has a pretty different pin-out (14 pin DIL vs 8 pin for starters...)
BUT! Had a closer look and its very easy to mod things for SSM2210 (or LM394) - I'll try it out and then post an image if its of use to anyone..
PostPosted: Wed Feb 28, 2007 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay- I'll dig it out, but you'll have to hold your horses until the weekend- I've got to dig my way out of a minefield right now Shocked Very Happy
ACHTUNG!
PostPosted: Wed Feb 28, 2007 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Found it. Though it may be a bit pixelated Confused
 Filesize:  246.59 KB
 Viewed:  16128 Time(s)
ACHTUNG!
Wild Zebra
PostPosted: Wed Feb 28, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
How is this possible? Do you need a converter or something? I have a Korg X-911 guitar synth and I thought it'd be cool to hook up to my Sound Lab (still needs 1v/oct mod) or my yamaha, for a few extra voices and modulations.
I also saw an article on modding the Univox K1/Minikorg for external cv inputs and gate. End result being Hz/V. So I thought about doing that down the line. But, It'd be cool to use my other synths.
"your stripes are killer bro"
bugbrand
PostPosted: Wed Feb 28, 2007 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Stefano - I got my one working today ---->> after a while though..!..
There's one big error in the project that could cause confusion - in the parts list, IC11 is listed as a 4011 but in the schematic its shown and listed as a 4001 -- !!! --- changing over from a 4011 to a 4001 got things working.
So, its working and tracking a bit, but at the moment its really very unstable - if you try re-triggering notes they'll often repitch themselves. The tuning ain't good at the moment.. HoHum. Maybe I'll try to get a ca3046 'cos I'm currently using an SSM2210 (with suitable cludges)
Anyways, just wondered if you'd identified that problem before...
PostPosted: Wed Feb 28, 2007 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
oh dear, another v-un-v guff! Laughing
I meant Hz/v Very Happy
edit; the oscillator frequency is controlled by a linear pot, therefore the control must be a linear response, hence Hz/volt Smile
But yes- the Korg stuff (mostly) is driven by Hz/v- including the MS-20
ACHTUNG!
StephenGiles
PostPosted: Wed Feb 28, 2007 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mmmm, no fundamental extractor, I can't see much possibilty of good stable tracking! Rolling Eyes
bugbrand
PostPosted: Wed Feb 28, 2007 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
StephenGiles wrote:
Mmmm, no fundamental extractor, I can't see much possibilty of good stable tracking! :roll:
To which do you refer? The penfold design or the MS20 design??
StephenGiles
PostPosted: Wed Feb 28, 2007 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Both.
Fernando
PostPosted: Wed Feb 28, 2007 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a V/oct to V/Hz converter that works:
http://rubidium.dyndns.org/~magnus/synths/schematics/
scroll downt to "V/oct to Hz/V converter" or
http://rubidium.dyndns.org/~magnus/synths/schematics/oct2hz.pdf
v-un-v wrote:
Indeed :D
The P-V converter on the MS-20 is what makes this synth so good. I've got the schematic if you need it. (although it isn't hard to find on the net). You can drive both the Soundlab and the SN7 voice from Hz/oct. So no more searching for tempco's? ;)
stefano
PostPosted: Thu Mar 01, 2007 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, it was the eighth message of this post (see previous page of this post, it was a message of mine). Anyway there are other errors (E), the article must have been written in a hurry ! For instance:
Evil or Very Mad E1) - there is listed in the schema of fig.2, for IC7 a CA4046 instead of the proper CA3040 (correct)
Evil or Very Mad E2) - IC2,IC5,IC9 in fig. 2 are CA3140, but in the part list (correct) IC2,IC9,IC10 are CA3140
Rolling Eyes E3) - spare terminals of pots VR3 and VR5, according to the schematic should be connected respectively to pads 'F' and 'B' (though, I wonder if this is relevant)
Bye
bugbrand
PostPosted: Thu Mar 01, 2007 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,,,, I really oughta learn to read through everything (..guess teachers were right..)
Question on the MS20 design ---
VR6 -> looks like it needs to be a triple pot ? do such things exist? never heard of them....
PostPosted: Thu Mar 01, 2007 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, and what about a Hz/V to V/oct converter? just in case i wanted try myself on the MS20 interface?
PostPosted: Thu Mar 01, 2007 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, in the old days they made such beautiful stuff Very Happy
But see : http://www.potentiometer.com/ , you can still have 'm - http://www.potentiometer.com/series308.cfm?session_num=2007030107075046 to directly go to a triple pot, or stackable actually.
Fernando
PostPosted: Thu Mar 01, 2007 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
oops, sorry, you are right we need the inverse conversion =:s
The MS20 was a very interesting interface
Wild Zebra
PostPosted: Thu Mar 01, 2007 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
yep this is what I meant fonik. I want to go out of the X-911 (Hz/V) into a V/oct. Sorry I kinda jumped in here. It's nice to see some progress on this project though. The X-911 tracks pretty well. I don't use it as much as I should. It gets alittle squirrly from time to time. It's all about finding the right picking strength.
StephenGiles
PostPosted: Thu Mar 01, 2007 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
The EH Guitar Synthesiser included a decent fundamental extractor which produced a sine wave from any input. As a result it tracked single notes from an electric guitar perfectly. Unfortunately it used 2 x CA3094, but they are still available at Smallbear.
Fernando
PostPosted: Thu Mar 01, 2007 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Harry Bissell told me that the Shin-Ei Octave's input section was great to condition a guitar signal for fundamental extraction.
This comment was around the PV1, a pitch to voltage converter by Harry based on a design by Bob Moog/Big Briar Etherwave Pitch to Voltage Converter. The PCB was sold by EFM some years ago (2000) as "PV1"
I'd like to post the schematic but I should ask Harry permission first, I guess...
Shin-Ei schematic
 Filesize:  19.43 KB
 Viewed:  16090 Time(s)
StephenGiles
PostPosted: Thu Mar 01, 2007 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://img.photobucket.com/albums/v317/StephenGiles/EH_sine.gif
Wink Wink Wink
Fernando
PostPosted: Thu Mar 01, 2007 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
yummy
:wink: :wink: :wink:
