Vactrol based VC-PANNER
Page 2 of 3 [56 Posts]
funkyfarm
PostPosted: Sat Dec 01, 2007 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
(as requested)
Funky40
G2 patch files: 5
PostPosted: Mon Dec 03, 2007 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Salue Funkyfarm
i have soldered the PAN part on a prototypingboard now,
but the CV part i do not understand .
what is unclear is the CV input section. ( and i cannot read all your writing )
ok, one input is just the pot between V+ and V-
I prefer it between -15V and +15V so i think i must add resistors. does somebody know which values ? 47K to V- AND V+ ?
CVin 1 is that with the 30k R (!!! Wink ) , thats clear
but what i need more is not clear.
I just like to have the simple PAN modul for first testing.
the offset pot and 2x a normal CV input should be fine, or not ?
i think i just can make it with 2x a normal CV input as shown for CV1, isn't it so ?
behind the 10K centre Trim are 2 resistors.
1 Value i cannot read.
They are just going to ground, no connection to the opamp ?
edit:
oh, and which transistors do i need. BC547, is that good ?
funkyfarm
PostPosted: Tue Dec 04, 2007 2:00 am    Post subject:
Subject description: Scott is your way to go !
All came from Scott Stites' Multiphase project.
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id19.html
Believe me, Scott's buffered +5v and -5v are part of the secret...
+/-15 volts ?
a simple voltage divider should work.
as seen on Scott's site wrote:
The other task was balancing out the XFade and CV control inputs to render a smooth crossfade. A range of 0 to 6.5V will give a smooth crossfade from one side to the other. I set the center trim to between 3.25 and 4 volts. I then created a +5V and a -5V source for the XFade controls to operate between. I scale that voltage down in the first stage of the control section with 33k input and 22k feedback resistors. I allow the external CV to have a slight bit more effect by using a 30K input resistor
edit:
Scott uses 2n3904 while I can remember putting BC549 here (so go with 2n3904 instead Cool )
"2x a normal CV input"
I guess only a single CV circuitry controls your PANNER (lightening VTL1-left output and VTL2-right output)
On my dual module, there are two separate CV lines (one for each module), but both panners share the same offset/center potentiometer (via a inverting buffer or not, thanks to a switch).
Hope it's (a little bit) clearer (for you) now (?! Very Happy )
Funky40
G2 patch files: 5
PostPosted: Tue Dec 04, 2007 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Funkyfarm.
It seems to be clear now. ( just had a look )
The descriptions given by you are very good
funkyfarm
PostPosted: Mon Feb 11, 2008 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I've noticed my module has a little extra gain (Us vs Ue).
You could maybe swap 110k resistors for 100k Embarassed
This is a great module.
I plan a dual cross fader for spring 2008.
PostPosted: Mon Feb 11, 2008 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
PCBs as well?
funkyfarm
PostPosted: Mon Feb 11, 2008 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
...no...and that's boring me...
funkyfarm
PostPosted: Sun Mar 30, 2008 11:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
(hmm, comin' soon)
funkyfarm
PostPosted: Tue Apr 15, 2008 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
It's alive !
In these 5.1 days, and fifty years late, I've decided to turn on stereophony !
This module even gave my modular system a new name : the brand new STEREO HERO system.
Cool
funkyfarm
PostPosted: Sun Sep 14, 2008 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've found a small problem : I can remember having trim the modules in order to have "a well-balanced stereo image" (LEFT=RIGHT) when intial potentiometer is at twelve o'clock.
But this seems to shift control symetry ; when I plug a perfect +/-5V lfo into CV input, my green LED dims more than my RED one...
I'll check trimming once more.
ericcoleridge
PostPosted: Thu Jun 04, 2009 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just wondering if anyone has attempted a layout for this Vactrol X-fade circuit? Would be great for VC cross fading waveforms, dry/wet signals, etc.
thermionicjunky
PostPosted: Thu Jun 04, 2009 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would like to see PCBs for these x-fade and panning circuits. I would buy a few of each.
mono-poly
PostPosted: Fri Jun 05, 2009 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes pcbs would be very welcome!
ericcoleridge
PostPosted: Fri Jun 05, 2009 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess this circuit is simple enough that one could hand-draw a layout for press'n'peel. I suppose I should give it a shot... assuming no one else has already.
mono-poly
PostPosted: Fri Jun 05, 2009 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's good free pcb design software?
Maybe i will give it a first try.
ericcoleridge
PostPosted: Fri Jun 05, 2009 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
This was posted today by Tim Servo in the 'layout factory' sub-forum (along with tips, etc.):
"I can highly recommend KiCAD as a PCB layout program. It can generate printouts if you etch your own boards, or Gerber files if you have them professionally done. It has a reasonable library of parts, and doesn't have any size restrictions (might be limited to four layers, but if you need more than that, you're probably laying out PCBs for a living using a high-end CAD tool). The best part? It's FREE!
http://kicad.sourceforge.net/wiki/forums.html/Main_Page "
widdly
PostPosted: Fri Jun 05, 2009 10:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built this on perfboard and used an on-off-on switch to toggle between pan-balance-crossfade modes. It's like the switch on the Universal Audio Processor of a Serge (at least I imagine it is, never having touched a real serge)
I used hand made vactrols and it works nicely although it is hard to get it properly balanced. Matching the LED brightness does not the vactrols.
Funky40
G2 patch files: 5
PostPosted: Sat Jun 06, 2009 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I have drawn a Board for the Crossfader, and built it also.
My one is out of balance and so not working nice.
There must be more circuitry on the Board then i have.
so glad to hear that the fault might be more on unmatched parts than on my Board itself.
should it not be possible just to add a Trimmer between power and LEDs to get this Issue under control Question
I have also one or i think two Boards for the Vactrol Panner, this is not built,
but i built one on perfboard. That one had faults, just debugged halfways. it was never running.
so nothing to share for now.
funkyfarm
PostPosted: Wed Jun 10, 2009 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
did you reproduce scott's control circuitry (relying on buffered +5v) ? with vtl5c series ?
Funky40
G2 patch files: 5
PostPosted: Wed Jun 10, 2009 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm, no.
I got now a bunch of little PCBs for TL79xx/78xx to make CV sources.
so should i just addon such a Board ?
widdly
PostPosted: Wed Jun 10, 2009 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used Scotts circuitry, but with homemade vactrols. The problem I got was that the same amount of current from the CV circuit would produce different resistances from the LDR's. However I could compensate for this using the trimmer....but then the front panel LED's would not be equal brightness when the pan was in the centre.
I could better match the LDR's or not mount the LED's on the frontpanel. Instead I just ignored since the sound is fine and the LED's look cool anway.
9u4f47ut
PostPosted: Fri Jul 03, 2009 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
seem to be having a bit of trouble with my homemade vactrols burning out in the Verbos crosspanning circuit ...any suggestions?
inform3r
PostPosted: Sun Jul 26, 2009 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone come up with a solid layout yet? I know it can be built on perf but a press 'n peel layout would be great. Like Eric said, this can be implemented in so many ways. That's why a dedicated PCB would be so nice.
I read through the whole thread and I can't exactly tell if anyone has successfully been able to get an even fade with this circuit yet. Seems like funky farm might have? What's the report?
funkyfarm
PostPosted: Thu Jul 30, 2009 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't know how to do pcb layout...
i was vexed for a long time with this project.
->veroboard
inform3r
PostPosted: Thu Jul 30, 2009 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
funky,
Why were you vexed? I don't exactly remember the details of the thread at the moment but for some reason I recall you eventually getting good results. Am I mistaken? Based on your post maybe it's not such an easy circuit? What exactly is the problem anyway? The schematic Scott Stites made looks really good. Mind you, I haven't tried it or gone over it with a fine-tooth comb. I would love to have a panner though. Especially one that uses vactrols. Plays right in to my vactrol/Buchla fetish.
-John
->veroboard
