Vactrol based VC-PANNER
Page 3 of 3 [56 Posts]
Goto page: Previous 1, 2, 3
funkyfarm
PostPosted: Fri Jul 31, 2009 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
vexed because i had to do it on veroboard...dual pan...dual crossfade...inverter/reversible pots on some cv...comparator mode implemented on all...mixers that mix PAN 1 L with PAN 2 L, that mix PAN 1 R with PAN 2 R, that mix XFADE 1 out with XFADE 2 out, and all, and all.
however i find it to be very clean, noise-wise.
This is a wonderful module.
i repeat it gave my system his (new...) name : The Stereo Hero system. Very Happy
(until i'll go 5.1...)
I don't clearly remember but I guess i only use it on audio signal, don't know why... (there's some DC caps on inputs ? maybe not ?)
ericcoleridge
PostPosted: Tue Sep 01, 2009 3:26 pm    Post subject: Re: Green / Red / Green / Red !!! Reply with quote  Mark this post and the followings unread
vtl5c3 wrote:
Is the inverting buffer at the input really necessary? I'm looking at the original Buchla 207 schematic and don't see any. I think the 1K resistor at the input is there to limit the input current.
Romeo,
Do you still have the 207 schematic? I'd really like to lay out a PCB for the 207, but I can't find the schematic anywhere. Would you mind sharing yours?
I was thinking I'd make some kind of hybrid of the 206 and this Verbos Vactrol Panner-- but the 207 is really what I'm after.
Chris
boosimas johnson
PostPosted: Tue Sep 01, 2009 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.synthfool.com/docs/Buchla/
ericcoleridge
PostPosted: Tue Sep 01, 2009 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW... thanks boo! I've never seen this directory before. I appreciate the link.
numbertalk
PostPosted: Tue Sep 01, 2009 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
He apparently just put these files up. Pretty awesome.
intellijel
PostPosted: Sat Jul 10, 2010 8:56 pm    Post subject: Re: Vactrol based VC-PANNER
Subject description: Mark Verbos design chekout
funkyfarm wrote:
Can anyone confirm that there must be a mistake in the voltage control stage of this design, found at Mark Verbos' ?
http://www.simple-answer.com/DIY.html
PANNER :
I have been looking at this circuit and trying to figure it out (mainly with respect to the vactrol controls and how the panning is derived).
Afaik the two transistors formed a differential amplifier but there are no resistors on the collectors for dividing voltage. (there are the diodes instead)
Also how come in this design the two emitters are linked by a single resistor?
