etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Berg
Posted: Fri Nov 14, 2008 8:34 pm Post subject:
Source code |
It seems that the link for the source code is dead. I'd like it if that could be fixed or if someone could send it to me.
Also, Etaoin what did you use to program the 68705? |
philpeery
Joined: Nov 08, 2006 Posts: 137 Location: new jersey, usa
etaoin
Posted: Sat Nov 15, 2008 1:01 am Post subject:
Re: Source code |
| Quote: | | Also, Etaoin what did you use to program the 68705? |
I built the programmer that is in the 68705 datasheet. The one that copies from 2716 Roms. _________________ http://www.casia.org/modular/ |
Berg
Posted: Sat Nov 15, 2008 3:56 pm Post subject:
Thankyou for the code philpeery!
So... any tips for a DIY eprommer and a suitable program to use?
I'm about to build a PIC programmer which also can handle a 24CXX eprom would that work? |
etaoin
Posted: Sun Nov 16, 2008 1:17 am Post subject:
You don't need a program to program the 68705. It actually contains bootstrap code and will program itself by copying the 2716. The best description of how it works is in the datasheet.
A PIC/24C programmer won't work. I don't think there are any other ways to program it other than having it program itself.
I've already created the hex files needed for the 2716 eproms for both the mts-100 and the adv-midi from the sources. I'll upload those as well. I also adapted the adv-midi code to use a normal hex encoder instead of the impossible-to-get grayhill-coded one. _________________ http://www.casia.org/modular/ |
etaoin
Posted: Sun Nov 16, 2008 8:34 am Post subject:
These come without any warranty...
(but these are the files I used to burn the 2716's and from those the 68705's)
The ADV-MIDI hexcode one is for a normal hex encoder (I used one from Omron; Mouser 653-A6A-16RS). The graycode file is with the original encoding table.
| ADV-MIDI with Omron hex encoder |
 Download (listen) |
| Filename: |
advmidi-hexcode-rom.zip |
554 Bytes |
| Downloaded: |
529 Time(s) |
| ADV-MIDI Graycode eprom bin |
 Download (listen) |
| Filename: |
advmidi-graycode-rom.zip |
556 Bytes |
| Downloaded: |
542 Time(s) |
 Download (listen) |
| Filename: |
mts100-rom.zip |
699 Bytes |
| Downloaded: |
550 Time(s) |
Berg
Posted: Wed Nov 26, 2008 7:10 am Post subject:
Okay... so now i might be able to get my hands on an old EPROM emulator but now the MC68705 seems hard to find as it is obsolete.
Is there any big advantage with this interface over the MCV-628 described here http://m.bareille.free.fr/mcv628/mcv628.html? It seems a lot easier to put together and comes with a config software.
Cheers |
etaoin
Posted: Wed Nov 26, 2008 12:22 pm Post subject:
No, the advantages are on the MCV-628's side. There's no real reason to build a midi-to-cv converter with the 68705 anymore, other than if you happen to have the boards and a couple of 68705 lying around. _________________ http://www.casia.org/modular/ |
