<on air> Bill Fox solo tonight! Chez Mosc
Nord Rack 2x help!
Page 1 of 1 [6 Posts]
telekomiker
PostPosted: Tue Jun 19, 2007 1:33 pm    Post subject: Nord Rack 2x help!
Subject description: No reaction of midikeyboard mod-wheel
Since a few days I have a new Nord Rack 2x with OS 1.00. Very Happy The sounds and arpeggio-variants are great. Confused My problem is a missing reaction of the midikeyboard modulation-wheel. No destination (Morph,LFO,FM..) on the rack give a response of the mod-wheel back.
Question Is my rack broken or have I make a wrong configuration on my rack?
Is the function only available for the Nord Lead 2x?
Friendly regards
telekomiker
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 19, 2007 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rack and Key version react the same to a extern ModWheel.
Are you sure the Wheel on the extern Keyboard is set up right?
Wout
telekomiker
PostPosted: Tue Jun 19, 2007 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Yes, my keyboard has the mod-wheel function for my other synths.
telekomiker
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jun 19, 2007 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suppose the Midi Notes are coming through...
Is there an Expression Pedal inserted at the back? If so, disconnect it.
Undo the Morph and try it again.
Set the parameter which is controlled by the Wheel closed (anti-clock wise maximum) - the Wheel decreases the parameter value for sure.
Are you sure the Midi setting is CC 1?
If nothing works, check Clavia support at www.clavia.se
Wout
telekomiker
PostPosted: Wed Jun 20, 2007 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Thank you for your ideas. Today I have found my mistake - the keyboard was in edit-mode. There can I change the midi-channel, but the mod-wheel is disabled. In play-mode the mod-wheel is enabled. My keyboard is a Novation Remote 61 LE. This is a help for other electronic-musicmaker.
telekomiker
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 20, 2007 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
It surely is!
What was the brand name of the controller?
Wout
