Nikmis
Posted: Thu Sep 06, 2007 5:13 pm Post subject:
mixer/multiple circuit? Subject description: first time caller, long time listener |
| what do people recommend as the best and easiest ways to make a 3-in mixer with 3 outputs thats good for preserving control voltage signals, like pitch CV, as well as audio? it doesn't seem too far out to me, but i couldn't find anything anywhere. |
crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Dave Kendall
Posted: Fri Sep 07, 2007 6:26 am Post subject:
Hi.
These are very useful, and small too......
They've got 2 outputs not 3 though. |
Nikmis
Posted: Fri Sep 07, 2007 7:27 am Post subject:
I was thinking of both of those, actually. But with the CGS mixer, would adding an extra output affect the circuit at all? with the Yusynth Mixer/Mfos distibutor combination, I suppose I could use them both together. They are simple enough, as well. And the yusynth and cgs schematics are pretty much the same, just the opamp setup, and then another because its inverted.
so that part is ok. but here is probably a dumb question; Does the MFOS distibutor work fine for audio as well. |
Funky40
G2 patch files: 5
Posted: Fri Sep 07, 2007 8:26 am Post subject:
| Nikmis wrote: | | . But with the CGS mixer, would adding an extra output affect the circuit at all? |
I build all my Modules with multiple outs.
In the past i just added some sockets without changing something.
Today i replace the outresistor with a wire,
and then i solder to each socket a own out resistor.
The newer mixer has a bufferstage behind the Mixer with TL072,
the older have not.
It works everything for me ! but it might not all be perfect  |
goldenechos
Joined: Jun 06, 2007 Posts: 201 Location: Marshall, NC
Posted: Fri Sep 07, 2007 10:11 am Post subject:
HIgh precision CV summing can be tricky. The op-amp choosen can have an impact on accuracy. You need something with low input bias and offset currents. I have seen the TL072 used with good success.
Try a combinationn of a resistor and low value trimmer in the feedback path of the second opamp so that you can trim to exactly 1V/ oct. (if that is what you are summing). If you are concerned with droop due to tapping multiple outputs I would suggest non-inverting followers (again, low input bias and offset currents) on each tap.
Probably you CV ins are fairly high impedence though, and the combination of that with the option to trim in more gain should set you up nicely.
TR |
