see a message indicating we are on the new server.
The Thomas Henry Mega Percussive Synthesizer
Page 9 of 31 [763 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, ..., 29, 30, 31 Next
Tim Servo
PostPosted: Sun Feb 24, 2008 3:45 pm    Post subject: The Thomas Henry Mega Percussive Synthesizer Reply with quote  Mark this post and the followings unread
bugbrand wrote:
Cool! & very happy to be able to help a little.
You're certainly gonna need a few Frac cases - you're going for 8 modules if I remember right! (enjoy the wiring!)
By the way, I'd forgotten to mention that my layout depends on using 16mm Alpha pots (or something of similar size) - being so tight, any bigger won't fit and I did have to bend all the legs up through 90degrees (actually makes it easier to make connections anyway).
A battery of 8 of these modules would be truly awesome! (though I'm sure I'll be perfectly happy just with two!)
Hint: 12mm Alpha pots. Good feel, D shaft, lots of values available. Readily available from Mouser. Although delivery in the UK might be more troublesome.
Tim (Mister 12mm, luckily that's not what my wife calls me) Servo
philpeery
PostPosted: Sun Feb 24, 2008 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
All of these posts are really making me want a bunch of these boards more! Is there any idea of when the MPS will be released "into the wild"???
Gotta have it!!!
Phil
Thomas Henry
PostPosted: Sun Feb 24, 2008 5:37 pm    Post subject: Re: The Thomas Henry Mega Percussive Synthesizer Reply with quote  Mark this post and the followings unread
Well, who does then?
Thomas Henry
PostPosted: Mon Feb 25, 2008 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i would be in for four PCBs. is it too late? i did'nt follow this thread entirely, but your samples made me wanting these PCBs, tom.
Undergrind
PostPosted: Mon Feb 25, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
not too late, as far as I understood. They said, that it will be in the store as soon as it is available.
I check the store everyday Smile for the 2nd run of the klee and the MPS.
www.myspace.com/undergrinder
Tim Servo
PostPosted: Mon Feb 25, 2008 9:57 am    Post subject: Re: The Thomas Henry Mega Percussive Synthesizer Reply with quote  Mark this post and the followings unread
Thomas Henry
See? It's moments like this that everyone needs a couple of MPS' to do the "ba-doomp-CHI" sound.
http://www.instantrimshot.com/
Wink
Tim (good evening, ladies and germs) Servo
PostPosted: Mon Feb 25, 2008 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now thats funny !!!!! Laughing Love the web site !!!
Bill
23isgood
PostPosted: Wed Feb 27, 2008 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok you know, I haven't been following this thread much but now that I heard T Bugs demo I want one of these now. Where is the shop by the way? I cant find it.
pete
Check out my music
Scott Stites
Audio files: 96
PostPosted: Wed Feb 27, 2008 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hit "front page" at the top, you'll find it. It'll be a while yet before these things hit the store - we're still going through the proto measurements with a fine-toothed Studs comb....
My Site
Scott Stites
Audio files: 96
PostPosted: Wed Feb 27, 2008 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or, better yet, hit "Store" at the top Laughing
My Site
funkyfarm
PostPosted: Fri Feb 29, 2008 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
did you plan, let's say...about 500 pieces as a first run,
or should I wait for the second batch to put my big finger on this little thing ?
Store button is almost erased from my screen, I can't stop hitting it...
zthee
PostPosted: Fri Feb 29, 2008 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
500 PCBs should be enough - I mean, I want atleast 4! Or do I need more?
philpeery
PostPosted: Fri Feb 29, 2008 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking in terms of 6 or 8! I would like to have an entire "kit" of MPS's, all driven from either a Midi interface, or some type of Roland-esque percussion pad. Now, imagine the setup that we would have if we could convince TH to update the clangora to a design that doesn't require those impossible to find 566 chips .....!
Phil
Thomas Henry
PostPosted: Fri Feb 29, 2008 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's on the docket for summer; it will also dispense with the NE570.
But first we've got to get the MPS out the door.
Status report: still testing the PCB and cross-comparing output levels.
Thomas Henry
philpeery
PostPosted: Fri Feb 29, 2008 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most excellent news! It's going to be e-drum heaven!
tommi
PostPosted: Tue Mar 04, 2008 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello! Sorry, I can't find the schematics for this (niiice) project. Anyone can tell me please? I don't even know if and where I can buy a pcb.
http://soundcloud.com/mister-vommi
http://tideofsound.net
bugbrand
PostPosted: Wed Mar 05, 2008 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tommi,
We're still beta-testing the PCBs - should get that done soon(ish) and then the project will be released through the electro-music.com store (up top - same as the Klee project).
http://www.bugbrand.co.uk
tommi
PostPosted: Thu Mar 06, 2008 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bugbrand!
I think that when available I 'll get two of those. Very Happy
Little problem: It seems that in Italy the XR2206 it's unavailable... Confused
Undergrind
PostPosted: Thu Mar 06, 2008 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
here in Germany its available at Segor:
http://cgi.segor.de/user-cgi-bin/sidestep2.pl?foto=1&Q=XR2206&M=1
Edit: I just fond it at Reichelt a bit cheaper:
http://www.reichelt.de
did I miss the BOM? Is it allready published? If so, where?
Thanks Very Happy
tommi
PostPosted: Fri Mar 07, 2008 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
No, you can't find a BOM. You can find just a list of the ICs (just six!) on page one of this thread... I think its the third post or so..
Anyway, thanks for finding the suppliers for me! Very Happy
bugbrand
PostPosted: Fri Mar 07, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, no BOM yet - but there's absolutely nothing hard to get (other than the slightly hard XR2206) - just standard resistors, caps, diodes and transistors (2n3904 & 2N3906 - ie standard NPN and PNP) -- all credit to TH for this!
You'll need, IC-wise::: 3x LM13700, 1 x TL074, 1xCD4046, 1x XR2206
tommi
PostPosted: Fri Mar 14, 2008 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes! I found the xr2206 (ordered two of them from my local reseller), i got six lm13700, two 4046, two tl074 and a batch of 100 2n3904 and 3906. So now I got all active components for the mps. I think I'll do on a wooden case and plexiglass panel like i 've done with the Soundlab!
I just have to wait for pcbs... Rolling Eyes I need those sounds!
Funky40
G2 patch files: 5
PostPosted: Sat Mar 15, 2008 8:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
please i really need to know around 2weeks previous when the Boards will be in the store.
I would be really pissed if i would miss them.
But i don't put myself on fire about such things.
And clicking every day to the shopp with the fear to miss it would be exactly that.
so please keep us informed here in advance!
thanks
PostPosted: Sat Mar 15, 2008 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I have good news!
After spending waaaaaaay tooo loooong getting my prototype together, I finished it this morning and fired it up. It worked beautifully first try, so we are not far away from a run of boards. Just a couple of test measurements to make, and we should be ready to Rock & Roll! (Ah, maybe that should be Kling & Klang!!)
PostPosted: Sun Mar 16, 2008 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick sample of my MPS supplying the kick drum with my Sorcerer doing a bass line. Both run from the Klee. There's a bit of shell CV modding the MPS to break it up a bit. I've only been playing with it for 15 mins or so, but it is proving to be very versatile, and a lot of fun. There are no dead spots on the pots, and the optional CV ins work quite well.
MPS kick.mp3
 Filename:  MPS kick.mp3
 Filesize:  280.61 KB
 Downloaded:  1879 Time(s)
