 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
CME Bitstream programming experience?
Page 1 of 1 [3 Posts]
jamos
G2 patch files: 41
PostPosted: Sat Feb 16, 2008 1:26 pm    Post subject: CME Bitstream programming experience? Reply with quote  Mark this post and the followings unread
If anyone has any experience programming a CME Bitstream, I have a couple questions I'd like to ask.
OK, specifically: I'm monitoring the output with a MIDI tool, and the instrument is sending an additional message along with the MIDI Start byte, anytime the Run button is pressed. If I try to delete the message, I get a cryptic message that says the length is too short.
BTW, this is a helluva strange little controller.. seems to be quite powerful, but the programming interface is kinda strange and the number of misspellings in the interface is laughable.. hopefully I'll be able to get this set up the way I want and then forget about ever programming it again.
Audio files: 297
PostPosted: Sat Feb 16, 2008 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please don't cross post, I removed the other one.
ar2jr
PostPosted: Tue Apr 22, 2008 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i had a difficult time with this thing. i could not, for the life of me explain why the dinsinc clock waivered as much as it did on this box...weird....
-matia
