loss1234
Posted: Sun Mar 30, 2008 5:59 pm Post subject:
problem getting gates AND CV from 4017 |
i have been trying to build a mini sequencer of sorts of based on the Baby 10 and a few other 4017 designs, but basically they all work in the same manner. However, here is the problem. I can only get the gate to trigger my Envelope on the start of each new cycle (so on a 4 step pattern, the gate only fires on the 1, not the 2, 3, and 4)
i am using a diode from each step, tied together into a jack for the gate out. for the cv, i am using a pot off of each step, with all the steps once again tied with diodes at the end to a jack. the cv works fine.
thanks _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
Joel
Posted: Sun Mar 30, 2008 6:14 pm Post subject:
I had a look at building one a while ago, I think the problem is these tend to have "gate" out not "trigger" - ie. for each step, the gate output is high for the whole step. As the gap between steps is essentially nothing (except where the sequence loops back to the beginning), the gate output is constantly high so you only get one triggering event. Have a look around for a gate to trigger converter, think one was mentioned recently.... |
RF
Audio files: 28
Posted: Mon Mar 31, 2008 12:50 am Post subject:
we would need a gate2trigger converter for each step before we mix the gates/triggers, don't we? _________________
Tech Buddy at Random*Source |
Joel
Posted: Mon Mar 31, 2008 2:06 am Post subject:
I was wondering, could you just tap off the 555 timer (presuming that is what is driving the sequencer) - as this goes hi-lo for each step of the sequence? |
Posted: Mon Mar 31, 2008 3:28 am Post subject:
sure, but using the input trigger won't enable you to switch on/off triggers for each step. _________________
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Mon Mar 31, 2008 3:54 am Post subject:
you need to use a gate to trig for every step
econimically , you can use a 40106 (or any inverter or nand ) to create a trigger from a gate for each step, as bugbrand told me in a lunetta thread:-
Quote: |
You can use a 40106 gate to change pulse widths (ie make a trigger) - have a look at the osc schem I posted --- feed a regular sqr through a low value cap and then into a 40106 gate, plus a 22k resistor tied to ground or V+. |
if that works, thats 8 gate to trigs a chip, i think it works by inverting a quikly rising slope - in inverse thats a quickly falling blip. cap size and resistor determins trigger length, you should try get it somewhere near 1msec ( I think this is electronotes standard, and a lot of circuits apply to that - not completely sure though ) . _________________ Clacktronics.co.uk |
richardc64
Audio files: 26
Posted: Mon Mar 31, 2008 4:38 am Post subject:
Mr Clack wrote: |
econimically , you can use a 40106 (or any inverter or nand ) to create a trigger from a gate for each step... |
Or, more economically:
eight AND gates, each with one input to a step output and all the other inputs to the 4017 clock in. _________________ Revenge is a dish best served with a fork... to the eye |
loss1234
Posted: Mon Mar 31, 2008 4:54 am Post subject:
loss1234 wrote: | fonik-your version has 2 gate outs. were you ever sucessful getting it to work as a gate source? is it possible that the gate out would work for "something"? |
i use the gate outputs to gate ADSRs, VCAs and VCFs - no problem at all. the thing is: the "merge-mode" is always ON. _________________
Clack
Posted: Mon Mar 31, 2008 7:21 am Post subject:
i think the baby 10 is a bit minimal , i think the advantage to it is you can have odd rhythems because the gates merge. you need to have switches to be able to turn off each step
(this?)
looks like it has an output jack per step and thats how it is done there. a gate to trigger per step shouldnt be to hard to implement if you want it _________________ Clacktronics.co.uk |
Posted: Mon Mar 31, 2008 11:17 pm Post subject:
yes. and i have a lot of fun out of it! _________________
loss1234
Posted: Tue Apr 01, 2008 4:09 am Post subject:
exactly. and as soon as you turn on two consecutive switches their gates will merge. _________________
RF
Audio files: 28
Posted: Tue Apr 01, 2008 5:20 am Post subject:
If I recall correctly, I used AND logic with the clock signal and the Gate from the 4017.
Sorry I don't have all the details on it - I recall I had to wrestle with it for a while til I got it to work.
bruce |
richardc64
Audio files: 26
Posted: Tue Apr 01, 2008 6:57 am Post subject:
very elegant. i will have to implement this to my baby10. a very valuable upgrade. _________________
loss1234
loss1234
Joined: Apr 03, 2004 Posts: 24458 Location: The Netherlands, Enschede
Audio files: 297
Posted: Tue Apr 01, 2008 8:38 am Post subject:
loss1234 wrote: | sorry for my ignorance but in that schematic are those tiny triangles backwards inverters or a switch?
(coming from the outs of the 4017) |
Switches. _________________ Jan
richardc64
Audio files: 26
Posted: Tue Apr 01, 2008 8:59 am Post subject:
Blue Hell wrote: | loss1234 wrote: | ...are those tiny triangles backwards inverters or a switch?
Switches. |
Yeah, I've been trying new symbols for my drawings. I should have left the arrowheads solid black and the switches open. _________________ Revenge is a dish best served with a fork... to the eye |
loss1234
loss1234
richardc64
Audio files: 26
Posted: Mon Apr 07, 2008 1:07 pm Post subject:
loss1234 wrote: | oops...sorry, i see a low value cap in the earlier reply. |
That's something you'll have to experiment with, depending on how short and long you want your "gates" to be and the range, which will be determined by the value of the pot.
I dunno: 100K to 500K for the pot and .01 or .001 for the cap is where I'd start. _________________ Revenge is a dish best served with a fork... to the eye |
widdly
Posted: Mon Apr 07, 2008 6:52 pm Post subject:
What about 20 steps from a single 4017?
I think it would work. Needs a dual-gang pot though and the clock needs to be 50% duty cycle.
